Question about Yamaha HTR-6080
No sound using digital coaxial connections
I have a Yamaha HTR 6080 (just purchased) connected to Toshiba DVD player (1 yr old) and Sony multi-disc CD player (old). I can get auido from all analog sources - radio, analog DVD, analog CD. I cannot get the digital connections to work. I have purchased a new cable just in case - no joy. Any ideas?
  • 8,596 Answers
Couple of possibilities:
Press Audio Select on front of unit until "Analog" changes to "coax/opt"
or
When you select the component connected to the MULTI CH INPUT jacks as the input source (see page 38), this unit automatically
turns off the digital sound field processor, and you cannot select sound field programs.
Posted on May 16, 2008
What connection do I use to connect a sony blue ray disc to on a Yamaha htr 6030 reciever to play music cd's
You said "...on reciever cd out in the audio box..." but it should the reciever IN that you connect to. Also is the BlueRay player capable of playing CD's ? When you press play on the sony remote, do the seconds start counting on the screen ? (ie: is it playing, but no sound is coming out?)
Dec 02, 2014 | Yamaha Audio Players & Recorders
Need to know what formats are supported by the Durabrand 1002 DVD Player.
The complete Detail would be :-
Product MPN MPN DVD-1002
Key Features DVD Type DVD Player Number of Discs 1 Progressive Scan With Progressive Scan Playable Disk Types CD (Audio), CD-R, CD-RW, DVD Video, Picture CD Playable File Formats JPEG, MP3
Audio Surround Sound Dolby Digital (Digital out only)
Connections Outputs Composite x 1, S-Video x 1, Analog Audio x 1, Digital Audio Coaxial x 1
Convenience Remote Control Standard OSD Yes
Other Features Exterior Color Gray
Miscellaneous UPC 017999010026
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | Durabrand DVD-1002 DVD Player
Yamaha HTR-5750 no sound when I turn to the DTV/Cable setting
If you are not getting sound on "Any" input except "multi channel" you have a bad DSP chip in the receiver.In short, you need a new receiver, it's a 500.00 repair. If you get sound on "All" inputs except "DTV/CBL" You need to get into the main menu of the Yamaha and select audio, toggle to input, then DTV/CBL and select "Auto". If you still do not get audio, it would be due to the version of HDMI software in your receiver. If it's under warranty, Yamaha will update hardware and software for you at N/C. If it's out of warranty, use digital coaxial or optical as your audio input for TV and run your HDMI directly to the TV. (The repair for this too would run 250-350) I hope I've covered all the possibilities. If you need further help, post a comment and I can help you more.
Aug 25, 2009 | Yamaha HTR-5730 Receiver
"Bose Home thearter 321, CD's not playing "Unsupported Format"
You do not give much information to work with. However, if you purchase a stand alone DVD player (I have a personal weakness for Sony, and only went with the Bose because of their sound reputation) make sure it has either optical out or coaxial digital which you can connect to one of the inputs at the back. Just note that in the Bose settings you have to assign Optical to the input you are using if you use optical. Optical and Coaxial audio are digital so you will not compromise the sound quality much.
It is not clear what type of CDs you are playing whether they are copies or originals. If copies how are they being burnt to disc, etc?
Aug 01, 2009 | Bose 3 2 1 GSX System
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
No sound from my htr-6030 when i hook it up to my dvd player with
If you can't use one of the Optical Digital Audio INPUTs on the HTR-6030, why don't you just use the Analog Audio Out on the HDD and an Analog Audio IN on the HTR-6030? It has one actually marked 'DVR', but any one would do.
Mar 19, 2009 | Yamaha HTR-6030 Receiver
Sub digital coax connection
You will need to get a y connector and split the sub out signal between the one it came with and your additional sub. The connector you need is an MFF, (1-male, 2- female) RCA type.
Good Luck,
BB
Jan 06, 2009 | Yamaha HTR-6130 Receiver
Hi, I just purchased a Panasonic Blu-ray Disc Plaer DMP-BD35. I am attempting to play the audio through a Yamaha HTR-6230 AV Receiver with 5.1 surround sound. I am using an optical cable. I am unable...
Check both for Optical
1) Check your DVD player make sure it is set to Dolby Digital or Optical Out or even AUTO (if applicable)
2) Check the Input source to the receiver say if you are using DVD on the receiver make sure the digital setting is set to either Optical or Auto
Nov 25, 2008 | Panasonic Televison & Video
Black and white video
Make sure there are not two video outputs emanating from the DVD player - this is the classic reason behind b/w picture.
Apr 01, 2008 | Yamaha HTR-6080
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha HTR-6080 Logo
283 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
