Question about Explorer Appliances BO693 Stainless Steel Gas Kitchen Range
I am working on a Explorer Gas Kitchen Range BO693, and was having a problem with it heating up, I ended up taking the back off the valve for the thermo cuppler is and was wondering how many turns the brass pice needed to be on the threaded stud
2 Suggested Answers
SOURCE: The glass from the top
I have one for sale, it was stored next to our range for a few years but never been used reply to make an offer plus shipping from (Tustin, CA.) brandogm@gmail.com
Posted on Aug 17, 2012
TAPPAN GAS RANGE MODEL NUMBER MPF500PBWD
the owners manual will not give you any repair info. Only use instructions. Your model has an oven safety gas valve that opens only after the secondary pilot heats the end of capillary properly. You may need to clean/replace the pilot assembly OR replace the oven safety valve. If you need the valve, look on ebay because these things are over $275 from Tappan.
Aug 21, 2014 | Tappan MGF500PBW Gas Kitchen Range
Roper gas range. Oven glow coil comes on but has no gas to heat?
if the glow igniter is on and it doesnt light its probably the gas valve
Feb 12, 2012 | Roper FGP300 Gas Kitchen Range
Oven does not heat up on Estate TGP305TQ Gas Kitchen Range. This problem just occurred recently. The oven has not been used much. I checked the power outlet and verified that the outlet to which the gas...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 01, 2011 | Estate TGP305TQ Gas Kitchen Range
Kenmore Elite Electric Rnage 2 years old model 790.9662. If you set oven to 350...never gets there or takes forever. I gave up after 35 minutes abd it was only at 235. HELP! PLEASE!
the gas valve on the back isnt on... the valve doesnt stop the stovetop from working, only the oven. You are seeing the ignition element heating up and thats slowing heating the oven.
Jan 11, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Free-standing gas range: my igniter works, but there is no flame - no heat. the burners light fine. It's only two years old but is the "no frills" model. Thanks for any help! Stopped...
Take a real good look at your ignitor. If it is dim orange it is weak and won't open the gas safety valve. It should be very bright. It oughta not take but 1 or 2 minutes to light the stove
I have more HERE
Thanks for using FixYa
Jan 07, 2011 | Frigidaire FGF326AS Gas Kitchen Range
I have a Tappan gas stove that takes forever to heat up (oven) and I smell gas before it starts to heat. Help?
Thanks for answering my questions. It sounds to me like your oven's safety valve is going bad. There have been many times when I am at a customer's house and it has been a while since they used the oven, and it seems to take forever to light the oven. Just tapping the oven safety valve with a wrench or handle of a screw driver is all that's needed to open the valve and light the burner. As long as your oven's igniter glow bar is lighting, (glowing orange or sparking), then the oven safety valve is your problem. It is a silver rectangular valve in the far back bottom of the oven with the orifice on top of it and the burner tube coming down over the orifice. Try tapping it and see if that works. Otherwise, just have it replaced. Douglas
Jul 03, 2010 | Tappan TGF657 Gas Kitchen Range
I have a stainless 30" wide gas oven/range. The oven works and the top burners will spark but I do not get any gas flow to the top burners.
If it is just installed, your gas valve inside the range might be shut off. take out bottom drawer/broiler. Look for a switch in the back near the gas valve, it should be turned to the right.
Make sure the burner heads are positioned properly with the alignment pins.
Nov 15, 2009 | Whirlpool GS460 Gas Kitchen Range
I have a Maytag MDR5755qdq gas kitchen range that will not turn on. The burners work fine. Do you have any suggestions.
Check the pilot and valve in the stove if it is gas. Make sure there is gas and pilot is lit. If it is electric, then check or replace relay/fuses to the heating element.
Jul 10, 2009 | Maytag MGS5770 Gas Kitchen Range
FRIGIDAIRE GAS STOVE GLGF377ASE OVEN PROBLEM
i would replace the igniter and go ahead and replace the gas safty valve eather the ignitor is not allowing enought amps to open the gas valve enough to light or the valve is opening to slowly eather way i would go ahead and replace both this could be very dangerious is not repaired.
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Gas range
Hi ,
Gas in insuffecient , clean the nozzle at back cover , take a small neddle push the the hole of nozzle . Thank You
Oct 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Explorer Appliances BO693 Stainless Steel Gas Kitchen Range Logo
76 people viewed this question
Top Explorer Appliances Kitchen Ranges Experts
Cleverer2
Vernon Taylor
Are you an Explorer Appliances Kitchen Range Expert? Answer questions, earn points and help others
