Question about GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White
My refridgerator is ticking like a clock. It's coming for the back of the unit. When I open the door the light flickers to the timing of the ticking. Everything is still cool, just noisy. It happened last night, while we were sleeping.
murdozzz2
  • 75 Answers
SOURCE: Freezer not freezing, fridge section not cooling
the problem you have sounds like the defrost heater is not being activated causing the evaporator to choke up with ice which will therfore restrict the airflow through the cabinet,
to resolve this problem you are best to defrost the unit and replace the thermal fuse for the heater' and the defrost sensor, both these parts are located behind the evaporator cover inside the freezer.
hope this is of help murdozzz2
Posted on Dec 08, 2007
docjohn174
  • 943 Answers
SOURCE: JENN-AIR REFRIDGERATOR JSD2789AES
HI thanks for your question. remove cover to the compressor relay, check for burnt wires. clean all coils. replace the relay. thanks
Posted on Oct 14, 2008
SOURCE: We have a 4 year old GE fridge that is ticking like a clock but louder. the model number is GBS20HBSBWW
If the inside fan does not come one, suggestions are "bad mother board", possibly a free replacement from GE, that otherwise is $300+.
Posted on Oct 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: refrigerator not cooling
Look into the back of the freezer and if there is a layer of frost building on the rear panel it's possible that your refrigerator is not defrosting. If yes unplug and remove the frozen goods to the fresh food section. Remove the rear panel and defrost with a hair dryer or by setting a large bucket of hot water in freezer and close the door until the ice is melted.There are a few reasons for this happening and they are defrost heater, defrost thermostat, control board and other things that could cause this because of the way the refrigerator is designed. But the most likely reason is the defrost heater and defrost thermostat. Try defrosting and then letting me know what you find. If you need one one one free assistance I am here for you! Let me know what you find, Thanks, Sea Breeze
Posted on Oct 28, 2009
SOURCE: appears there is a bad connection or switch
I have the exact same problem. Except mine will go out of temperature range. I have replaced the thermistor in the fridge and it hasn' resolved the problem. The temporary solution I have come up with so far it to unplug the fridge from the outlet to clear the motherboard and then plug it back in after 10-15 mins. It sometimes lasts weeks, then acts up again. I'm guessing it's a motherboard. (my next step)
Posted on Jan 13, 2010
Light flickers when door is opened
it has connection problems when you open the door of freezer connecting wire turn gradually and one time comes up light normally,you repair connecting wire of lights.
Mar 23, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
Craftsman 53918 - 3/4 hp, belt drive garage door opener. Wall unit says safety sensors misaligned. Replaced them as suggested by manual, no fix. Does not appear to be any power from where you plug...
The main light flashing 10 times is the sign of a door sensor problem. Check to see if the small light on each sensors is lit and not flickering. If you cannot get both lights to come on your sensors or the wiring to them is bad.
Sep 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a chamberlain liftmaster professional Formula 1 Garage door opener that has been working for 5 years. Now will not go down unless you hold the main button. Sensors blink when it hits within 3...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. They each have a small light that should be lit, both should be the same brightness and not flickering ever so slightly. If not tweak them a bit. If both lights will not come on you have bad sensors.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Sears Craftsman K1026 05/94 139.53779 HBW0709 appears to be locked. my garage door goes down and immediately comes back up
If the main light flashes 10 times when the door reverses it is a problem with the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have bad sensors.
If the door hits the floor and reverses to the open position but the main light does not flash it is because the door is traveling too far. Locate the 'down limit' control on the side of the motor unit and turn it in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary.
Jul 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Bought a new remote yesterday, programmed and still the same problem. Backed out this morning and the remote would not shut the door. Came home and it opened the door, no problem. Did notice the indicater...
If you are referring to the LED on the back of the motor unit flashing 4 times, that is the code for door sensors misaligned. Check to make sure the small light on each sensor is lit and not flickering ever so slightly. The flickering is sometimes very hard to see but it will cause the problem you are describing.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
The garage door does not stay down.Comes back up with lights flashing fast.The sensors are clear and the pressure has been set.
If when the door reverses the main lights flashes 10 times it is a door sensor problem. Nothing else will cause this. Make sure the light on each sensor is lit and not flickering ever so slightly. The flickering can sometimes be difficult to see.
Fridge stopped cooling, ticks and light inside flickers in time with the ticks. fuse blown? can it be repaired? I've taken off the back case to have a look in case anything was disconected, but all looks...
YOU MIGHT HAVE A DEFOST FAULT- LEAVE THE DOOR OPEN FOR A DAY AND TRY IT AGAIN- IF IT COMES BACK IN A COUPLY OF WEEKS THEN DEROST IS FAULTY
Jul 06, 2009 | Refrigerators
May 27, 2009 | GE GBS20HBSWW 30" 19.5 Cu. Ft....
GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White Logo
144 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
