Question about John Deere Garden
I have a 1987 John Deere 855 compact diesel utility tractor with the foot control 2 range hydrostatic transmission. Some times when I push on the forward pedal, and most times I push on the reverse pedal, the tractor will move a few feet and then seem to slip out of gear and emit a faint grinding noise. On another site, I saw a response to a very similar question from another 855 owner and he was told that the bolt on the driver gear had backed out, and that he needed to pull the hydro tranny and replace the bolt, washer, and 2 "O" rings. Do you guys have any other thoughts or ideas ?
  • 479 Answers
SOURCE: John Deere LT190 Lawn Tractor transmission problem
try to service the old transmisson it may work.but if that does not work just replace the transmisson.
purchasing a new hydrostatic transmission is much advisable as its definately the problem of hydrostatic transmission with out any doubt .but i hope servicing the old works.
Posted on Oct 01, 2008
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
  • 246 Answers
SOURCE: Left side headlights and tail have no power coming
Hello feeze1:
>>Using a Continuity Tester (Multimeter) and Check the Wires.
>>From your Description it Sounds like there is a Broken Wire in the Harness.
>>Usually I Route a New Wire or Wires to the Effected Light Assemblies if a Wire in the Harness is the Cause of this Problem.
>>On Most Units it is a Hassle to Repair a Wire or Locate the Exact Break in a Wire in the Harness.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
Where is the serial number for a john deere 4105 compact utility tractor and what do the numbers mean
follow the link to a picture of the location
http://www.greenpartstore.com/John-Deere-Model-4105-Compact-Utility-Tractor-Parts.html
Aug 23, 2014 | Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
Can't connect hydralics on my new John Deere 1025R
release pressure on hydraulic lines by pushing in ball at end of line .will have to push in hard or tap. fluid willl squirt out a little
Jul 13, 2014 | John Deere 420,1020,2010,2020,2510,2520...
1981 John Deere 1050 Diesel Tractor - Engine will go to high idle by itself. You can shut key off and engine will eventually die. What would cause the engine to high idle? Afraid engine will lock up.
There are 2 types of governors on diesels. one is controlled from the foot and is fixed speed at the foot setting. The other is variable speed which will run to high idle if the setting is not changed IE on start it will idle ok but if you use a fast setting on a hand throttle say to warm up the motor it will run to high idle. I suggest that if you have not had a problem before then you should have a diesel pump specialist look at it as there may be a fault in the governor control.
Jun 23, 2013 | John Deere Tractor Side Screen...
I have a John Deere 3720 ran over a small branch wich disconcted 3 small wires underneth my tractor. Now I have no forward hydrostat it has been in the john deere dealer for 2 weeks they can not figur
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Aug 29, 2012 | Cars & Trucks
John Deere L130 will not back up a hill
Could be a problem with you hydrostatic transmission fluid, the dealer can replace the entire transmission (this is usually the course they push) and with labor will cost around 700$.
Mar 13, 2011 | John Deere Garden
My John Deere 4310 compact tractor hydrostat transmission does not work. I got on top of a tree stump and now it will not move. Trouble code light flashes one long then three short flashes. Please help.
You likely knocked a wire out of the forward or reveres potentiometers,which are located under the right floor pan and are attached to the foot pedals.If they are in place then they may have bee hit and now need to be re-calibrated,if so call your J.D. dealer.
Jun 14, 2010 | John Deere 4020 Gas & Diesel Tractor...
John deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Jun 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Jun 09, 2009 | Diesel Garden
Garden Logo
383 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
