Question about Krups XP7225 Espresso Machine
Error code 6 on Krups XP 7225 compact automatic espresso machine
SOURCE: instructions for Krups Gusto espresso maker
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={F506FE01-D7EC-414A-BEC1-AE53E62990C6}&SelectedProdRef=F880
This is the manual :)
Posted on Jan 25, 2008
  • 14 Answers
SOURCE: krups xp 7240 cofee machine
6
Pump in actuator down phase
The flow has not dropped (> 50ml/min)
after the actuator has been filled to the
maximum (80ml); there is a water
leakage and the actuator does not fill
Look for the leakage source:
hoses, actuator, priming valve?
Switch or distributor switch
control fault: incorrect detection
of cams  error in distributor
position in cylinder descent
phase.
Flowmeter hoses changed over
Distributor problem (leakage at
drain ..)
Faulty connection between the
2 picto boards
If no leak detected, replace
power board V26 with V29
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
  • 3 Answers
SOURCE: No espresso coming out.
The problem with the XP4050 is the two safety valves that the water goes trough on its way to the coffee head. They are plastic and some of the parts will just become brittle because of the hot water and the contamination they gather. With my XP4050 they just broke and parts of it were in the rubber tubes that go to the waste tank.They are also very cheaply constructed compared to the more robust parts of this machine. The water to the hot water/steam head does not have these valves and has a completely different routing. I am currently trying to fix the machine with just one valve and parts of the two valves that are still good. Fingers crossed....
Posted on Jul 20, 2010
SOURCE: krups xp7420 espresseria automatic
am o proare 01 la un espesor krups 7220/7240
Posted on Aug 09, 2010
Machine fault error No 0C
0C
Faulty communication between the 2
boards
Disconnect and reconnect the
coffee-maker
Overconsumption on low voltage power
supply: Distributor blocked, does not turn
Determine the cause
Dec 16, 2013 | Krups XP7230 Compact Super Automatic...
My Krups XP 9000 showing "Service 2 contact hotline" Has anybody figured out how to fix it. Krups has been no help on this one they said they do not have a service manual on it. They never made one.
I think that error code means it needs a new motor driving unit for the brewing unit. Tell me what it does in detail when you attempt to make a coffee. screaming_skull@hotmail.com
Oct 03, 2013 | Krups Super Automatic XP 9000 Espresso...
Krups xp 7225 replaced piston, reassembled and is now dead, power switch seems ok and all wires firmly attached
Your Power Switch Part No Ms-0675088 need to change.,your
machine have appear any error No ? God Bless
Joseph
Jul 23, 2012 | Krups XP7225 Espresso Machine
Error code oa will not preheat
you need to get to an authorized service center.
Try http://www.smallappliance.com/repairsmain.asp?cur=USD
Mar 04, 2011 | Krups XP7230 Compact Super Automatic...
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
Error code 06 on a Krup XP7245
remove calk-filter in watercontainer..
Jun 28, 2009 | Krups XP7230 Compact Super Automatic...
I need a manual for krups xp 7240, krups xp 7200, krups xp 7230
I have the manual, send an email to me at inouside@hotmail.com and I will reply to you with the manual in pdf format.
Mar 04, 2009 | Krups XP7230 Compact Super Automatic...
Krups XP7225 Espresso Machine Logo
952 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
