Question about American Standard 2770.018w.020 Cadet Whirlpool White
When I turn on the whirlpool, black flakes come out & into the tub water. I tried running it with chlorine bleach in the water, but that didn't help at all. The problem is getting worse as time goes on. I'm afraid it's in the hoses, but I have no idea what to do.
  • 4,349 Answers
Go to a hot tub company, they have scale type cleaners that do this job. It does require draining a few times, but it is worth it.
Posted on Sep 18, 2010
Air jet tub shoots out black flakes
it sounds like there is a build-up of some kind in the lines. Replacing the lines may be your simplest solution. Replacing the entire system would definitely fix the black flakes.
Dec 27, 2013 | Home
Black flakes from jets
It is biofilm growing inside your plumbing. The black flakes are most likely biofilm. Check out specific cleaners designed to remove that crud. The best is called OH YUK
Apr 22, 2012 | Whirlpool Home
I just viewed a bunch of complaints about chlorine bleach getting dumped on the subsequent load, but did not see a true root cause response. 1st question: When you use chlorine bleach with the whitest...
chlorine bleach is a highly corrosive addition to laundry that is not necessary... try Borax and Hot water. If the clothes sat in the Bleach for the entire wash cycle it would damage them and shorten the life of the clothing fibers considerably...
Apr 21, 2017 | Whirlpool GHW9400 Front Load Washer
When washing towels black mould marks are seen on the towels. Towels are also getting holes.
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
If your washing is getting holed, it could be because of incorrect use of chlorine bleach being poured directly onto clothing, unfastened buckles and zippers in the wash, ribs and tears and broken threads in the materials and overloading the washer. Degradation of the fabrics could also be a contributing factor.
Apr 27, 2011 | Whirlpool Washing Machines
Please help me I have a American Standard whirlpool tub. I have flakes coming outta the tub when the water level reaches the jets.I have bleached the tub turned the jets on, drained the tub and did the...
Are they white flakes? Sounds like you have lime deposits turning loose in the plumbing.
Was the unit purchased and installed new? Maybe the privious owner had a hard water problem.
In either case, you may have to invest in a water softener.
HTH,
Mike...
Dec 07, 2009 | Water Heaters
What are the black flakes and how to we eliminate
Did you buy the machine used? It sounds like mildew rinsing off of the outer tub. Try running a load of judt hot water with bleach to clean it out
Sep 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
Washing machines staining clothes with a blackish stain
The bearings under the tub may be leaking grease and it will get in the tub.
Jul 31, 2009 | GE WSXH208A Front Load Washer
Two person jacuzzi that hasn;t been used for several years. Iron
You are on the right track. Be sure and chlorinate and run the jets at the same time I would let it set for at least a couple of hours running the jet intermittantly and then drain and repeat.
Sound like you have Iron Bacteria. You may want ot contact a water profeessional who can recommend ways of getting rid of the iron.
Properly Chlorinating your well would be a good first step.
What part of the country are you in>
sanray
Dec 19, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Musty smell
probaly a good wash with chlorine bleach..fill tub with hot water pour 2-3 cups bleach let agitate for few mins stop machine and let set 20-30 mins restart and let finish cycle ..to head of future problem leave lid open between uses
May 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
American Standard 2770.018w.020 Cadet Whirlpool White Logo
409 people viewed this question
Top American Standard Home Experts
Mike
john h
Tom Chichester
Are you an American Standard Home Expert? Answer questions, earn points and help others
