Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Black line when using feeder. I have cleaned with alcohol the glass, rubbers, everything, as suggested. Just tried scanner, same line appears.
    Genius:
  • 1,089 Answers
Determine where the line is...right side, middle, left side. Lift the ADF up. If you have to lay the paper down on the glass and match the line to the glass. There has to be a piece of dirt in that area. Sometimes it helps to gently run your finger of the glass(where the line is). Feel for any abnormality. Try a magnifying glass. There is dirt there. That's the only thing that will cause a black line when using the ADF. Check the underneath of the ADF cover for dirt.
Posted on Sep 14, 2010
The photocopying using the feeder leaves a black line
There is a separate scanner glass from the flatbed scanner glass.
Without a make/model I cannot tell you exactly how to access it, but once you have uncovered the document feed scanner glass area, the glass will need to be cleaned well, and then you will be able to scan from the feeder without the black line appearing.
Jul 27, 2011 | Office Equipment & Supplies
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
Every time I scan lines appears either on document or pictures. I tried cleaning the glass but nothing happens.
Clean the **** glass with alcohol. The **** glass is the little glass that paper is scanned over when using a automatic document feeder.
Jun 18, 2010 | HP 5590 ScanJet Flatbed Scanner
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Jun 14, 2009 | Brother MFC-7420 Printer
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Black line
try cleaning the scan glass, there should be a thin scan glass that the paper runs over when you use the feeder that may have white out or some other foreign object on it, try cleaning this using rubbing alcohol and a cloth rag
Feb 25, 2008 | Sharp AR-168D Copier
Problem while copying
O.K. guys,
the problem is with the smaller glass on the left.
Lift the top and look at the small glass on the left, is there a dot, whiteout, dirt etc... on there? that is what's making your lines. clean with alcohol or mild cleanser.
Nov 07, 2007 | Kyocera RI-3530 Black and White Copier
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Sep 29, 2006 | Canon DR-1210C Scanner
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
300 people viewed this question
Seeker5211
Seeker5211
