Question about Samsonite Case & Tripod Kit for Digital Cameras / Camcorders
Broken lock on samsonite suitcase - Samsonite Case & Tripod Kit for Digital Cameras / Camcorders
SOURCE: suitcase number locked combination forgotten
f'lite Samsonite combination lost and stuck locked:
I removed the lock unfastening the 2 torx screws from the case.
Next I removed the pin that holds the RED tab thingy in place and the spring ( all this does is pushthe assembly to the right when a number is moved..... Take a picture of this before you dissassemble it. push it allthe way through..if you have fat fingers you are screwed. Anyway, remove the red thingy, and then carefully lift the remaining plate out taking note of the orientation.
First of all: the solution is aligning the cogs to 0-0-0 like from the factory. This is easy to do. when you remove the plate above , carefully do so without launching the dials and the spring into space....no matter.
Look at the bottom of the plate and notice there is a notch that will correspond to the cogs still in place on the lock assembly that should still be in place.
The cogs sit on a spring that sit on the backside of the dials with the numbers you can see when locking the suitcase.
Here is the meat:
1. with your finger or something turn the cogs until the black dot aligns outmost.
2 align the cogs so that notch will correspond to the orientation on the plate you just looked at. (that's it)!
Carefully replace the plate with finger pressure and actuate the latch-it should be unlocked and at the 0-0-0 position. If not repeat 1 and 2.
Push the pin through again, through the red thingy and the spring. BAMMM! you just saved your self a zillion dollars...still having trouble...mail this to me and for $15. I fix it for yaz....
Posted on May 29, 2008
  • 3 Answers
SOURCE: my combination for samsonite suitcase no longer works what to do?
Is it locked shut?
Posted on Jun 22, 2009
SOURCE: I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
SOURCE: I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Posted on Oct 17, 2009
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
I was having the same problem now... I OPENED THE LOCK !! by inserting a scissor blade into the keyhole and gently turning it !! It worked and the lock opened !! :)
but now my lock is NOT getting LOCKED !! :(
what to do ?/ Please help !
Posted on Sep 28, 2011
How to reset a combination lock for samsonite luggage?
if the suitcase is open, look for a little red tab on the inside. Move it to the other side of the little window, then change the combination. If the suitcase is locked, you will have to try from the outside to find the correct combination
Mar 11, 2015 | Samsonite Photography
How to change lock code in TSA007 lock?
Nov 30, 2012 | Samsonite Tripod
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
Please tell me how to set teh lock code for my samsonite silhouette 11 HS....no instructions were included! help!!
Sure... here're the instructions - open the suitcase, then open the zipper in the modesty pouch (it is mounted on the backside of the suitcase, along its entire length), and then from in there, take out the plastic packet. In the plastic packet are labels, warranty information, AND voila - the instructions to set the combination lock... :-)
I would tell you here too:
1. Open the suitcase
2. Look at the inside back of the lock - you would see a red color tab, and two markings - A
Aug 30, 2010 | Samsonite Silhouette 11 SoftSide 22"...
How to unlock 3 digit lock in samsonite suitecase
mcdevito75 here, You"ll have to find a store that carrys suitcases in your area for help or, you can try to contact Samsonite online at Samsonite.com
Jun 23, 2010 | Samsonite Silhouette 11 HWatch
Oct 16, 2009 | Samsonite Tripod
Apr 11, 2009 | Samsonite Tripod
Samsonite Case & Tripod Kit for Digital Cameras / Camcorders Logo
1,279 people viewed this question
Top Samsonite Photography Experts
ittco
Level 1 Expert
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
