Question about Sony RDR-GX300 DVD Recorder
The drive, model DW-U15A, on my Sony RX900 needs to be replaced. I cannot find another.
  • Daren Egan May 14, 2012
    Post removed
  • 905 Answers
Finding a replacement is next to impossible. However, you may be able to repair this drive if the only fault is that it will not recognise disks.
WARNING: The following instructions involve opening your recorder and being exposed to dangerous voltages. make sure you unplug the unit from the mains supply before opening the unit. DO NOT PLUG INTO THE MAINS WITH THE COVER REMOVED.
1. Eject the disk tray and then switch off the unit at the mains socket. Remove the plug from the socket for safety.
2. Unclip the front bezel from the disk tray. Push the tray back in.
3. Remove the top cover of the unit. Remove the front plastic bezel from the unit (should be clipped on).
4. I am not familiar with your particular model but you will probably need to loosen one or more boards inside to gain access to the actual DVD unit.
5. Remove the DW-U15A. Take the metal casing off the DW-U15A.
6. Slide the laser carriage back, away from the center. You will notice that one side if the carriage is firmly attached to the slide rail while the other side can be wobbled up and down on it's rail. There should be very little actual wobble. Unfortunately, the grub screw used on the carriage at this point is made from plastic instead of metal. So over a period of time this grub screw gets worn down and eventually the carriage leans too far over for the laser to bounce off the disk correctly.
7. You need to adjust the white grub screw to adjust the angle of the carriage (and therefore the laser). You will need a small ALLEN KEY (HEX key) or you can try a small flat blade screwdriver. The grub screw is locked by a small amount of coloured resin which will need to be broken.
8. The adjustment of the grub screw will basically be a case of trial and error. Turn the grub screw about a quarter of a turn CLOCKWISE (i.e. it should move down to lift the carriage up) and then reconnect to the main unit. put the cover back onto the unit and plug into the mains. Test the drive.
9. If it does not work then repeat step 8 until the unit reads the DVD.
10. You may need to fine tune the adjustment by trying a range of pre-recorded and home-grown DVDs.
11. If it still does not work after two or three full turns of the grub screw then either the laser unit is too dirty or the laser has failed, in which case you definitely need a replacement drive. Try finding a working DRU-510A and swap the control boards.
Posted on Oct 11, 2010
  • 5 more comments
  • IanHamilton Feb 06, 2011
    Thank you for this solution. It worked perfectly and my Sony RDR-HX900 now plays every old and new, commercial and home-brew DVD and CD that I can test it with. I've yet to try recording but can't see why that should not be OK too.
    I varied the solution slightly. Firstly, before changing the position of the grub screw, I made a tiny mark with a fine spirit marker to help with judging the angle of change. The "wobble" before I changed anything was a good 1.5-2.0mm. So I turned the grub screw until the wobble reduced to zero. This took about two and a quarter turns so I went for a single change of one full turn. I wanted to avoid too many iterations as the fragile connectors were not meant ot be fiddled with too many times. So a single change of one turn did the trick. Thanks again.
  • nibbsuk May 16, 2011
    Thank you for that excellent advice ! The grub screw on mine tightened some 2-3 turns, and I opted to wind it up fully then back it off a quarter of a turn. It works on several DVD's, but I can't say I've performed an exhaustive `all types of media test`. I'd have been more happy to test different media at different screw settings if it wasn't such as ba***rd to dismantle and re-assemble !
    Thank you for posting that tip.
  • Charles Garrett Dec 09, 2011
    Thank you for that excellent advice ! The grub screw on mine tightened some 2-3 turns, and I opted to wind it up fully then back it off a quarter of a turn. It works like new
    Thank you again for posting that tip. Finding the grub screw was the thing.
    Chuck fromGR MI.
    Raj, you are the man!! My Sony RDR GX300 has been getting worse and worse at reading and recognizing DVD's lately (both home-grown and store-bought). Took it apart, adjusted the DW-U15A per your instructions (and nibbsuk's suggestion), and it works like it's brand spankin' new! Thank you!!! Sorry guys, I meant to post this for Raj and not for malexop. Oops, sorry!
  • dhod7669
    dhod7669 Apr 14, 2013
    This solution worked for me too, thanks for the tip.
  • djnic
    djnic Jun 19, 2013
    Thanks a lot! Its working! The best solution! All is working!
  • dvd981 Jul 23, 2013
    Thanks Raj! I tightened the plastic grub (set) screw on the drive of my Sony RDR GX-300 DVD Recorder. It took about a couple turns until the laser carriage could no longer be moved. Then I loosened the screw about 1/4 to 1/2 a turn until the laser carriage started moving freely again. It looked like the laser carriage was now sitting about a millimetre higher than before on the grub screw side. I tried out the disc open/close and suddenly discs that were previously giving me an error message could be loaded properly and played again. This problem started when a few of my DVDs couldn't load anymore and over a few months none of my DVDs could load. The gradual onset of the problem made me think that the laser lens was dirty. That's why it was so puzzling to find it clean. But all along it was the gradual erosion of the set screw that caused the problem. Thanks again for some great advice!
I have a Sony RDR-HX900 which I love, but the DVD burner recently began giving error messages stating that the disc is unreadable. This was for blank DVD-R as well as commercial movie DVDs. I was afraid that my beloved HX900 was at the end of it's life, until I found this post. It took about an hour and a half, mostly trying to figure out how the various parts were removed in order to gain access to and remove the burner. I finally got it out, took it apart, and adjusted the grub screw in a quarter turn. After reassembling everything, I tried burning a video to a blank DVD, and voila! It worked perfectly fine and plays and burns DVDs perfectly once more. Thanks to the OP for posting these directions!
Posted on Dec 05, 2012
  • Maltytasker Dec 05, 2012
Dear Ray, this was an excellent hint. The Recorder refused the read some DVD's, specifically rewritable blank Discs. After following your instructions it now reads and writes without any problem. Thank you for posting this solution.
Posted on Feb 15, 2016
Thank you for the advice. I also can fix this problem. Although there is a small (8x5cm) Z shaped aluminum bracket which I cannot put back because I do not know its place when I assembled the device, and I do not find its place in the service manual neither, but the recorder works correctly. :)
Posted on Jun 03, 2012
Sony dvd+rw dw d56a plays cd's. doesn't see dvd's at all. I hear the disc spinning. Doesn't see it. control panel - double clicked on drive - nothing
It is possible that there could be some garbage in the processor do to a small power surge and if you unplug the unit from the wall for 40Min., it will reset back to normal.
Mar 09, 2011 | Sony (DW-D56A-10/20) (DWD56A1020) DVD...
Hi, I have SONY DVD/CD rewritable drive unit, Model No. DW-Q28A. CD or VCD working but DVD not able to work .
The drive is compatible with the following DVD Disc:
WRITE SpeedDVD+R DVD+RW DVD-R DVD-RWDVD+R DL
DVD-R DL
If you are unable to burn using those disc then the burner is defective.
If you want to watch a dvd then you would need to purchase or download a program to watch the DVD movies.
Feb 28, 2011 | Sony Computers & Internet
I have a Sony DVD RW drive model # DW-D18A that acts-up at times. The tray won't open at times and when I finally get it to open it won't stay closed. I'll close the tray and it opens again. Is this a...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 17, 2010 | Sony (DW-D18A ) (DW-D18A BG) DVD±RW...
When I put in a new a recordable dvd disc in my RDR GX 300 it will format & then it says this picture can not be recorded, even though I have previously recorded the program on my DVR from Directv. I...
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Feb 27, 2010 | Sony RDR-GX300 DVD Recorder
Will Not reconise Cd or DVD in the Drive
Yes, this drive is basically dead. You can find pretty cheap prices for new drives at www.pricewatch.com
If the drive door closes on a cd or dvd that you want and it will not open back up, use a straightened paperclip and push it into the little hole near the door on the drive, the door will pop open then.
Mar 29, 2009 | Sony DW-G120A DVD RW Dual Layer Burner
Sony Dvd recorder/player drive needs replacing
I have the perfect solution never ever BUY ANYTHING with the sony name on it.
Oct 21, 2008 | Sony RDR-GX300 DVD Recorder
Sony dvd rw dw-g120a
I cannot burn my home movies to my dvd drive, my dvd drive is called SONY DVD RW-G120A, it says this device is disabled Code 22, Please help me fix this problems. Thank you
Oct 15, 2008 | Sony DW-G120A DVD RW Dual Layer Burner
Dvd/cd rewritable drive unit sony model dw-u50a
You can try the Sony website or go here:http://www.opendrivers.com/driver/210528/sony-dw-u50a-dvd+-r-+-rw-drive-firmware-1.5a-free-download.html
Jun 18, 2008 | Sony VAIO GRX550 Notebook
Sony RDR-GX300 DVD Recorder Logo
7,567 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
