Question about Old Town Charles River Canoe -
We would like to know if anybody knows how to fix spiderweb cracks and cracks in the outside shell on the bottom of our canoe?
    Master:
  • 502 Answers
Whats it made of?if its fibreglass,you can sand it down[around the cracks]and relay the fibreglass cloth with the special glue,and build it up.follow the repair kits instructions..reasonably cheap to fix
Posted on Sep 21, 2010
    New Friend:
  • 3 Answers
If fiber glass then take a small drill bit and place a hole at each end of the cracks then fill will fiber glass resin. This is the quickest and most efficient way to rid of cracks. if you decide to lay resin in the cracks prior to drilling at each end then the cracks will come back. sand when finished. fiberglass is very easy to work with. if you "mess up" then just sand it down and reapply.
Posted on Apr 03, 2014
    Novelist:
  • 269 Answers
Do they leak? If not, then leave them alone.
Let me repeat -- Do they leak? If not, then leave them alone.
They might not look great, but if you start to fix them then you have to sand off a lot of material and repair with cloth and resin and re-finish and it is a big job.
Posted on Jul 21, 2012
What can I do to fix a screen that is cracked?
Order a new screen or send to iResQ for a 24 hour turn around time!
Oct 17, 2014 | Samsung GALAXY S4
Front screen has a spiderweb crack. how can we fix this?
No, there is not. Its normal to replace the whole applicance.
Dec 20, 2013 | Toshiba TP50G90 50" Rear Projection...
I just received the family canoe my husband had when he was little from my sister-in-laws who has kept it in the back yard for the last 12 years. It is in need of some TLC. The paint has wore off in...
Go to a local marine/boat store. They carry fiberglass repair kits for boats that should work on the canoe. There are systems out there that will coat the canoe and make it last a long time. They also have gels that restore the shine to fiberglass that are pretty amazing, but you would not want to put that on before restoring the damaged areas. Using marine-grade plywood would be a good start, but then seal it with a spar varnish in a can to give the wood a long life. The crack in the panel should be sealed as water can collect in that space, hopefully the outside hull only has the cosmetic cracks that can be filled before re-gel coating it or polishing it.
Aug 29, 2011 | Dolphin Boating
Hi, I have 2 plastic canoes and one fiberglass canoe that have cracks or small holes that I would like to fix. Is there one quick and easy repair method that can fix both types of canoes? I dont care if...
both can be fixed with fiberglass mat just be sure to sand them so the resin has something to bond to to and tape the outside with wax paper and make all the repairs from the inside
Jun 24, 2011 | Boating
Royalex canoe -wood trim. I live in Canada down to -35F. this winter. I forgot to loosen screws ongunnels. I now have completely through vertical cracks through screw holes in royalex. Suggestions?
Are there washers on the plastic side of this boat? You could get some stainless finish washers to grab the plastic instead of just the screw head. I'm not really sure what you have there without seeing it, If it is that bad, you could also take another piece of wood, to match the gunwale on the outside and put one on the inside. Then drill some neat holes and run screws into the thicker one. I have a strip canoe, with the 2 gunwales, and have no problems with draining the boat or anything like that. Of course we don't freeze down here.
Feb 10, 2010 | Mad River Canoe Boating
There is a large split to the bottom and side
I don't have any info on how to fix this, but I do know that wooden canoes can be very heavy, so you may want to look into getting a lighter one, i.e. fiberglass.
Oct 11, 2009 | Boating
Bottom of canoe is cracked under the front seat almost all the way across can it be repaired
Is it made from plastic or fibeglass or alum?  For plastic or fiberglass I would try a very good epoxy. For alum. I would try to find some one to weld it. There are some very good epoxy's out now. 3m makes a panel adhevsive for auto use that will fix just about any plastic/fiberglass you may have.
Aug 24, 2009 | Boating
Canoe has damage on the front bow.
Bondo would probably work.
Also, you could laminate a few pieces of something like vinyl siding/facia board over the hole. If the canoe is ABS, the vinyl siding cold be "welded" / fused to the ABS with PVC primer & solvent/cement.
May 27, 2009 | Coleman Cable Coleman Inflatable Boat...
Easy way to fix cracks and lost covering on the outside of a buffalo canoe due to sun exposure
There is no easy way. Get rid of the canoe. It is not cost effective or even worth trying to resurface a gone surface. Sorry! The good news is that when you go to e-bay or craigslist on your computer you can replace for cheaper and get a better canoe than had you repaired yours. Your canoe would gain weight and you would never feel secure that a breach in your hull would not be forthcoming! Buy a new-used canoe hopefully made of kev-lar or a similar poly substance. Fiberglass, wood and metal all have pluses but the minus's outweigh the pluses. You want "O" maintenance and longeviety of product and usage. I hope I have helped you. Check out my blog at http://wwwcaptcookrules-robbin.blogspot.com I've got a segment on canoeing you might enjoy. Happy canoeing! RB
May 01, 2009 | Boating
Cracked Iphone Screen
You can buy the LCD screen and repair it yourself. You will find the replacement part in the link below, as well as a video that explains how to install it:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/LCDiphone3g
Jul 31, 2008 | Apple iPhone Smartphone
Old Town Charles River Canoe -  Logo
270 people viewed this question
Top Old Town Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Old Town Boating Expert? Answer questions, earn points and help others
