Question about Kenmore 62802 Electric Dryer
My kenmore model 76873100 wont spin and the belt is in place
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 15, 2010
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore 70 series wont spin
the belt broke,send the model number and i can tell you how to get at the belt and the part number.
Sep 30, 2011 | Kenmore Dryers
The washer drum wont spin.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
How do I change the drive belt?
Unplug the dryer.
Remove the lint filter.
Remove the 2 screws at the lint filter opening.
Use a putty knife between the top lid and the front panel to release the clips.
They are about 2 inches in from right and left sides where the top meets the front panel.
Lift the lid towards the rear of the dryer.
Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside.
Place the new belt over the drum,ribbed side towards the drum.
Look under the drum for the belt tensioner. It is S shaped with a wheel on it.
Place the base of the tensioner in the slots below the motor pulley.
Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel.
Place this side of the belt over the motor pulley with the ribbed side touching the pulley.
Replace the front panel.
Hook up the door switch wires.
Replace the panel screws.
Reattach the top lid and lint filter screws. Replace the lint filter.
Plug in the dryer.
Jan 03, 2010 | Kenmore Dryers
Wont spin
worth repairing, can likely do yourself. check the lid switch, it is probably your problem. comes complete with wires that plug in. easy fix.
Nov 08, 2009 | Kenmore Washing Machines
My kenmore washer will not spin or agitate. It
i dont know what model this is, but hopefully its a belt type.un plugg unit, place on its side and check if belt is broken or slipping. if enclosed transmission type, it is a big repair.
Sep 04, 2009 | Washing Machines
My clothes dryer wont spin
broken belt. If you want to do it yourself you will probably need a few simple hand tools and a trip to sears or an appliance place for a belt. check to make sure though. see if you can here a motor working. if you do than it is the belt.
Aug 28, 2009 | Kenmore Elite HE4 Electric Dryer
My front load kenmore 417-44072300 wont agitate or spin
you have a belt broken, drain out the water and take the back of machine off and you will find the belt then go to a place that sellls appliance parts andget a new one
Jul 18, 2009 | Kenmore 43042 Front Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
My washer wont drain nor spin...
don't suspect yet for the belt! if the motor runs then the belt could be the problem but not exactly! you could tighten the belt by adjustments of some components.
for the drain, make sure that the drain hose is placed down. try to look for connection for the drain knob going to the drain outlet. it could just be a cut/broken line!
notice also if there is a leak (water) on the bottom of the washer spinner. if it has, then the water seal has worn out causing slipping and poor spinning!
Nov 15, 2007 | Kenmore 22942 Top Load Washer
Kenmore 62802 Electric Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
