Will a stk392-570 interchange with a stk392-110? Also is there a website where I can find which stks are compatible with each other?
  • 1 more comment
  • Patrick McAlexander Sep 14, 2010
    I was they would work. Zenith R56W28. I've had to replace the resistors and the 392-110 twice in the last 6 months.
    I will try some 150s. Yeah I have been cleaning them with contact cleaner so its not an issue.
    And thank you for the help.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
No, they are completely different chips. Give me brand, model number.
If you need know best place to buy I can tell you that also.
REGARDS, SD TECH
Posted on Sep 14, 2010
  • SD Tech
    SD Tech Sep 14, 2010
    A few thoughts here: 392-570 is a completely different part than -110.
    With that chip, a few things to do----Upgrade to STK-392-150 and make sure when you replace them you REMOVE ALL THE OLD HEAT SINK GREASE (I presume you did put fresh grease when you replaced them) and clean the heat sink with denatured alcohol or acetone---if you did not do that the old grease acts like insulation---poor heat transfer.
    I do this for a living, I buy mine from SUBURBAN ELECTRONICS in Maryland--they have a online catalog and also are on EBAY----select there advanced search, then search by seller-----sewsales55 is this company.
    A pair of the STK-392-150 chips is under 14 dollars.
    If you have had to replace them in less than 6 months one of two things is wrong----(other than heat grease issues already mentioned) either you just got un-luckly and got a bad one or the set has a problem where the chips are pulling TOO MUCH CURRENT---if the set was operating I would use my hand (after it is on a while) and touch the metal heat sink (just one hand)---IT SHOULD BE MILDLY WARM AND THE FACE OF THE CHIPS SHOULD BE COOLER.
    Good soldering is also important and cleaning bottom of board and using liquid solder flux is also important---a bad solder connection can also cause this kind of problem.
    Let me know if you have questions -------I AM HERE TO HELP YOU.
    SD TECH
X370
There are adapters available to fit the old Minolta manual-focus lenses on Sony alpha-series dSLRs as well as Sony NEX-series interchangeable lens cameras. The lenses obviously will not autofocus and, depending on the lens and camera body, you may lose some or all exposure metering capability.
Nov 26, 2012 | Konica Minolta Minolta 110 Zoom SLR Mark...
Convergence problem
my name is rico i work on tvs sometimes. First you need to poen the back of you tv, second look for the ics in board. they start with stk393 or 392 . like skt393-110 or 393-120, or 392-040. After you find those stks, you need replace them and check for bad fuses or resistor for the right ohms. if you need those stks, I have them, please feel free to call me anytime. 602-810-7149 i live in mesa az
Dec 30, 2010 | Toshiba 43H71 43" Rear Projection...
Sir I live in los angeles area, and I need to puchase a a tv convergence (stk392-110) do you have any idea or know a spicific store to purchase this parts
hello my name rico and i work on tvs sometimes. i have those stk392-110 available, please feel free to call me for the stks at 602-810-7149.
Dec 29, 2010 | JVC Televison & Video
I had a convergence problem with my pt51hx42f. I
Youl likely used bad chips. Only buy your chips from a trusted source. Try www.tvrepairkits.com ...
Apr 20, 2010 | Televison & Video
I am seeing double on my tv how can i fix this problem.thanks
Replace Both of your STK ICs and 5 or 7 low ohm resistors if your stks are 110s , 150s, upgrade to 180s.STKs are your convergence ics they are the big black ics will have part number on them STK392-110 etc...
May 20, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Blue light (RGB) will not converge (Toshiba 50H72)
Look around the area of the STKs and you should see some low valued resistors. One lead of which will be attached to the STKs. One or more of these is open. Replace it/them and you should be fine. These are current limiting resistors (effectively fuses) for the power to the STKs. One of them is not getting power.
Dan
Jan 23, 2009 | Toshiba 43H70 43" Rear Projection...
Mitsubishi VS-50705 convergence problem.
There should only be a couple of STKs, the R's are resistors, they STKs should cost under $20. This should be everything you are looking for. If you need anything else, let me know.
CHASSIS: VZ7
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
Ref # / Part # / Part Name & Description
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
Jun 05, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Convergence problem
go to www.audiolabga.com. Look on left side of screen. Select STKs now scroll down to the STK 392-110 and the data sheet will be next to the price of the part. The data sheet will answer your question.
Kimberly Moran
Georgia do-it-yourself geek
Mar 28, 2008 | Televison & Video
Ic question
No change in resistors is necessary. The -150 can handle more power but will only handle that which is presented. I'm assuming that you are talking about the convergence STKs.
Dan
Mar 19, 2008 | Televison & Video
Memory cards
You may be able to store up to 110 images if you use the camera in its lowest resolution mode. In high resolution, you may get only 24 shots. We wish we could tell you precisely, but it depends on the exact size of the file created by a given camera, as well as the resolution that you select. Keep in mind that Secure Digital, CompactFlash, and SmartMedia memory cards are competing products and are not interchangeable. You'll find a few cameras that are compatible with more than one brand, but generally when you buy a digital camera today, you'll be making a commitment to work with one type of memory card. Use the attached chart to determine the average number of photos that Secure Digital memory cards can store (compatible with most HP digital cameras)
Sep 08, 2005 | HP Photosmart 120 Digital Camera
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
