Question about Dell Precision M60 Notebook
Connecting laptop to tv
Dell m65 connecting to panasonic lcd tv using cable with male blue connector from laptop to tv using green/blue/red cable ends.
  • 37 Answers
1. If your tv has a PC input, use a vga cable, from any normal computer monitor.
2. If you use those HD connectors, match them to the correct colour coded inputs on the tv.
In each case, do all the connecting with the computer POWERED OFF. Then when connected, boot the computer, and allow Windows to auto-detect the 'new monitor', as it will 'see' it.
Then you shoud right click on your desktop, choose properties, and goto 'settings'. From there you will see monitors 1 and 2. click on the new monitor and 'enable' it.
You also have the option of 'extending' windows to the second monitor, as well as making this your 'default monitor'. Experiment to see what best suits your needs,
Erik.
Posted on May 16, 2008
How do i connect my hp2560p to tv
You can use a VGA cable to connect from your laptop to your TV.
10FT 15 PIN BLUE SVGA VGA ADAPTER Monitor Male To Male Cable CORD FOR PC TV
Just make sure you have a connector on your TV....If you only have RCA inputs, you can buy an adapter. just plug it into your laptop and run the Red, White and Yellow to your TV with RCA cables.
VGA SVGA to Video 3 RCA AV TV Out Cable Adapter Converter PC Computer...
Thanks Hope this helps!
Please rate
Gary
Mar 17, 2014 | HP Elitebook 2560p Notebook 12.5" 2.5gI5...
Cantdisplay pic from pc to tv
To use a Panasonic Toughbook CF52 model
on a TV, you require a TV with a VGA Port.
The VGA port is a 15-pin female connector,
usually BLUE in color and you will require
a MALE-MALE VGA Cable which is also
BLUE color on the two ends.
The Panasonic has to be shut-off and the
cable connected to both the Toughbook and
the TV. Turn the TV on first and set SOURCE
on the TV Remote to "PC".
Then turn on the Panasonic Toughbook CF52.
If everything is properly connected then it
should switch automatically to the external TV.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Feb 20, 2014 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
TV picture goese black and white
Check your cables on the back of the TV and cable box. You either have it connected wrong, or they are loose. If you are using red green and blue, make sure that you are tightly in the red green and blue connectors. If you are using yellow white and red, then make sure you don't have the yellow in the green spot.
Mar 20, 2013 | Dell W3706MC 37 in. LCD HDTV
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
Green vertical lines displaying on the LCD screen in my Dell Precision M65 Laptop. Can you please help me to solve this issue.
it the problem with lcd it seems to be increasing day by day last you will find full white colour
Apr 26, 2011 | Dell Precision M65 Notebook
How to connect acer travelmate 4720 with LCD TV useing S-Video ports? Will just one connector cord connecting the Acer 4720 with my LCD TV suffice for reciveing and audio-visual through the TV?
Hello, You will also need to connect the audio cable. You can use a male-male audio connector from radio shack along with the s-video cable to solve your problem.
Apr 08, 2010 | Computers & Internet
How do i connect my laptop to my television
You need a VGA to TV cable. If your TV has a component input, you need a VGA to component cable, like the following one:
http://www.amazon.com/Male-3RCA-Component-Video-Cable/dp/B000SJ2TJ8/ref=sr_1_9?ie=UTF8&s=electronics&qid=1266279733&sr=8-9
The VGA connector is for your laptop (you connect in on the side) and the RCA connector (3 plugs) is for your TV
Check your TV for a green, blue and red connector on back.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Thank you
TechSaver
Feb 16, 2010 | Toshiba Satellite L505ES5015 NoteBook
Connect dvd recorder to cable box and hdtv
I have posted a tip that should help you out with your problem follow the link below but there is one minor variation for connecting to your TV.
On step 3 of the connections section substitute the follow for your situation.
You will need 1 component cable (Red/Blue/Green/Red/White cable)
3) Connect the Green/Blue/Red connectors to the back of the DVR labeled "COMPONENT OUT" matching the colors. Connect the same ends to the input of the back of the TV again matching the colors.
4) Connect the last two connectors (Red/White) to the back of the DVR to the AUDIO IN on the TV.
Other than this variation all shoud be the same.
CLICK HERE for complete tip.
Good Luck...
Jan 27, 2010 | Panasonic DMR-E55 DVD Recorder
Scheme for the VGA Cable of Acer AL1511eb
You will have to buy a 13 Pin Din Male Connector cord. Use the break-down below to help with reconfiguring.
Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 N/C Not connected Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 +5 V +5 V DC Pin 10 GND Ground (VSync, DDC) Pin 11 N/C Not connected Pin 12 SDA I²C data Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 SCL I²C clock
Nov 24, 2008 | Computers & Internet
Dell Precision M60 Notebook Logo
197 people viewed this question
Alun Cox
