Question about Dishwashers
Diswasher used to get dishes clean. now there are spots, film and food remnants on dishes after cycle completed. The dishes look awful
  • Dishwashers Master
  • 5,603 Answers
Check taht the detergent is getting dispensed and the water is hot and you can hear the water spraying.
ALSO refill the dispenser for the liquid sheeting such as JetDry. That is usually in the door with a twist out plug. It usually lasts 6 months or so.depending on the use.
Posted on Sep 14, 2010
  • micheleheath Sep 15, 2010
    Thanks but The detergent is dispensed, the water is hot, I use Cascade and Jet Dry. I checked the filter screen and its clean and the spray arms arent plugged. Still baffled??
  • Fred Yearian Sep 15, 2010
    A possible prioblem MIGHT be if part of the pump impeller has been damaged reducing the water spray pressure. They often use a second impeller for draining so only the cleaaning phase would be affected in that type machine. A key thing is if you can hear the water being aggressively sprayed.
    Other things might be if you overload the machine... we often do and run ours on HEAVY for a longer cycle. Yet another thing is if pots or other things with handles might impede the rotaating of the spray bars. We have had pot handles or things that hung too high or through the racks that blocked the spray bars from turning.
    Another thing is to open the washer during the cycle to check that the water level is right.
    Lastly, verify the rinse cycle is working.... that might be where the problem is... IF the timer is mechanical, a bad switch contact might prevent the proper rinse.
    I am trying to suggest all possible things I can think of...
My dishwasher does not clean the dishes even though it completed the full cycle
is it a film or spots? if so its your water and not the dishwasher actually. go to www.dishwasherfilter.com and check out their filter system. it works great and should solve your problem.
Jun 24, 2013 | Dishwashers
After running a full cycle the dishes have a film left on them. Sometimes soap is not rinsred off the dishes. Tried different soaps for dish washers. It seems the only thing to take the film off of the...
Film on dishes post cycle is caused by 2 things.... Poor water flow during the wash / rinse cycle.... i.e clogged sump inlets or restricted drains. Clean the drain hose first. Start at the cink connection and clean EVERY connection and in-line componenet from the port hole at the sink connection all the way back to the drain hise connection port at the dishwasher.
If you still have dirty dishes post cycle after drain cleaning... then remove the lower wash arm support and clean the accumulator / sump area thoroughly. See this link: (items 1 and 4) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140844&diagram_id=28222738#d28222738
Test again.
If the problem persists you will have to gain access to the pump impeller. Inspect the impeller, and pump housing for damage. UNDER the dishwasher. Item 22 of the above link.
This should get your diswasher performing properly again.
I used this model number as a reference: GU2400XTPB1
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Our maytag is about ten years old. No big problems that a little vinegar wouldn't solve once in awhile. Lately, we ran out of water softener salt and a white film was on dishes and not getting clean. I...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 28, 2011 | Maytag 24 in. MDB4100 Built-in Dishwasher
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
White film especially on ziploc containers and utensils. Glasses come out spotted and clear glass dishes are streaked with a white film
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Please post back if more information is required.
Daniel
Aug 07, 2010 | Dishwashers
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
A white nasty film on the dishes after washing
Check to make sure there are no bits or trash or paper around the bottom parts of your dishwasher. Place a bowl of vinegar on the bottom rack of your empty dishwasher. Run your dishwasher through a complete cycle.
Mar 23, 2009 | Dishwashers
Have very strong film build up on Bosch diswasher
two things that works well may sound funny but it works get yourself a packade of thang orange juice crystal dump it in the dishwasher let it run a cycle it will cleane the film of the interior anothe thing that works verry well is clr it is a mild acid you will find it at your homedeot or any hardware store trust me it works i have been using is for 30 years i am in the comercial dishwasher busness i see this every day thanks from gilles
Mar 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
6 month old GE dishwasher now leaves heavy film on dishes...
As far as using the vinegar, this should be complete when there is NOTHING in the dishwasher. The idea is to remove the build up inside, not clean the dishes. Make sure to use only White Vinegar. Also, changes in the water of any kind can cause a build-up. Try using a little less detergeant and rinse.
Dec 29, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Washing leaves spots
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water. First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions. If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. See "Doesn't wash well," above. Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps: 1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra hot settings, such as "Power Scrub" and use "Energy Saver" dry cycle. 2) Adjust detergent amount. 3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
