Question about Rowenta Powerglide DM273 Iron
Rowenta Effective Iron - Model DX1700-U1 NRB01-01
This is my 3rd Rowenta iron in 3 yrs. Suddenly, this one will not heat. I used it, unplugged it and later plugged it back in but it will not heat. I shook it around to see if auto off/on was engaged but to no avail.
Should a Rowenta iron last only one year and if so, why is the price so high? I keep thinking perhaps I got a "lemon" but after the 3rd. iron in as many years, perhaps Rowents = Lemon.
Any suggestions to see if this $50.00 is down the drain too?
Rita A. Schiefen
  • 2 more comments
  • ma_stevenson Aug 17, 2008
    My mother-in-law just gave me two of her Rowenta irons with the same problem. As soon as I can find a hollow point Torx 15 driver to get the tamper resistant screws out, I hope to open them up and take a look. Right now one lights only for a while, then when the thermostat opens (reaches temperature) it never re-closes to heat again. The other has no light...dead.
  • plcooper21 Aug 22, 2008
    My Rowenta will not get hot. Red light blinks on the handle. Have had it less than a year. Did I buy a defective product?
  • Anonymous Oct 23, 2008
    I purchased my first Rowenta Iron less than 6 months ago, I have the same problem my iron does not heat up the small light on the handle blinks off and on and the light on the base will sometimes go on.
  • ma_stevenson May 11, 2010
    Actually it takes a hollow-point Torx 20 to get the tamper proof screws out. Once inside everything comes apart easily. The problem seems to be with the motion sensing switch (a.k.a. "auto off"). Instead of using mercury, they have used a mechanical ball swith with contacts. It seems that the contacts must get dirty or worn over time by the constant movement of the ball. I can get mine to work after taking it apart and reassembling it again, but the next day it will not work. However, if I leave it upright on its back stand and DO NOT MOVE IT, then it turns on the next day just fine. It is almost as if the little motion sensing ball gets hung up on something and cannot move unless man-handled pretty roughly (such as in taking it apart). Wish I could find a new part, but do not see any on the internet. Anyone know of a source? It is a small white plastic box, potted with epoxy...part number R30105M (for the Model DE334 - SurfLine). Thanks!
I just drop it a few times on the floor really hard a few times and then it gets hot again!!!
Posted on Sep 14, 2008
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
We have a Rowenta iron effective model DX1700, less than a year old. It will not heat. Is there an iron made that will give satisfactory service for more than a year? Are they repairable?
If the cord and plug are ok (the wires in the cord often break just at the cord protector at the iron) the most likely other problems will be the thermal fuse(s) or the element. Thermal fuses can be replaced but if the element is gone that is unfortunately that. Take the back cover off and check for continuity from the plug to the inside connections using a test light or multimeter (the iron is of course unplugged).
Jan 19, 2011 | Rowenta Irons
ROWENTA AIRLIDE MODEL #DX1900 IRON WILL NOT
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 12, 2010 | Rowenta Irons
What is the best way to clean my Rowenta iron.
I always run the DG980 till the steam runs dry, unplug and let cool. Rowenta recommends using clear water ONLY. They even provide a small hose & faucet adaper to flush out the steam tank reservoir.
Since it sounds like you do not have it, the next best thing is to use filtered water (I have a 3 cylinder water filter in the kitchen for drinking water), The tank has a plug on the side which should be removed once unit is cold, tank flushed with filtered water and drained completely and leave the treaded metal plug and trim cover off to air dry completely, as well as the blue tank.
May 24, 2010 | Rowenta DG-980 Iron
Rowenta iron will heat up and then shut down. Have to keep plugging and unplugging the iron.
Irons use a potentiometer and thermister to control the heat on the element. One of these components is bad and needs replacing. If the iron's still under warranty, get another one. The cost of service would probably be as much as a new iron, but you could call an appliance repair shop to check.
Mar 12, 2010 | Rowenta Professional DM890 Iron with Auto...
Rowenta surfline iron turned off and won't go back on.
heatman101
Jan 27, 2010 | Rowenta Surfline Iron DE-333 Iron
Rowenta d1700 red flashes and iron shuts off
I am on my 3rd or 4th Rowenta. I recently bought the Rowenta Effective, Model DX 1700. Once again, I am having the same problem as before, it shuts off after about 30 seconds. From what I am reading, many people are having the same problem. I'm going to have to guess, this is a product defect. Do I contact the company for a refund????
Dec 03, 2009 | Rowenta Effective DX1700 Iron with Auto...
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
Mar 14, 2009 | Rowenta DX6700 Iron
Iron does not heat
Inside the iron is a piece of thermal metal the is supposed to make contact with a small ceramic pin with a metal cap on it. I think this was intended to be a safety device but they fail and the iron will not heat up. The part does not seem to be available so easiest way to fix is to put a small bead of glue on the housing that forces this to make contact.
May 16, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta Powerglide DM273 Iron Logo
564 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
