Question about Western Digital Caviar SE16 (WD5000KS) (5000KS20PK) 500 GB Hard Drive
Installation i installed a Western Digital internal hard drive and im trying to install the software but it keeps giving me an error opening software. im assuming its because im using windows vista. is there any downloads out thee that i need to install the driver on my new hard drive
  • 36 Answers
The hard drive will automatically install you do not need to install a driver. I'm guessing this is a hard drive in addition to the hard drive that vista is running on? If so you probably need to format the hard drive to gain access to it. Click the windows button, and in the search field type compmgmt.msc and hit enter. Click continue when the UAC pops up. Now inside the Computer Management Console find and click on Storage and then Disk Management. On the bottom portion look for your new hard drive. Most likely it will have a black colored stripe and say UNALLOCATED. This will explain how to do the rest Yes that article is for XP but the one in Vista is pretty much the same.
Posted on May 16, 2008
Recovery discs won't install windows on new hard drive
sad to say but probably have to buy a new operating system disk .
May 13, 2015 | HP Computers & Internet
The driver software cant be installed
While you r opening the hard drive what error do u get ??
Nov 23, 2011 | Western Digital My Passport Essential SE...
My western digital passport drive has the following issues. 1. when I play a movie it keeps stopping and starting like its streaming. then it will eventually freeze up. 2. I have tried several times to...
First, check your computer to make sure it is keeping up with the job. In Windows, open Task Manager (Control-Alt-Delete), click on Performance, and look for the CPU graph. If it is maxed out, or if the amount of memory in use is greater than the physical memory installed in the computer (using the internal hard drive for memory), the computer is having trouble keeping up with the workload. Quit any programs not needed for playing the movie, including those resident in the task bar. You may also need to do a scan for Trojan Horses stealing processor time. Add more physical memory if necessary and possible. In Mac OS X, open Activity Monitor and check the CPU and System Memory tabs.
There are at least three external hard drive models that meet your description, including one designed for playing movies (Passport AV). If you are running Windows, try the "Data Lifeguard Diagnostic for Windows" download for the Passport Essential to see what it finds. Save it and install it on your computer's internal drive, then use it to check the Passport unit.
If that doesn't fly, you may have to disassemble the Passport and install its hard drive as a second internal hard drive in a computer. Use a S.M.A.R.T. diagnostic program (Data Lifeguard, or one of the Linux equivalents) to inspect the drive's internal problem tracking registers. If the diagnostic program works on the Passport, but reports problems with the drive mechanism, that's your answer.
If the drive works properly inside a computer, but misbehaves in the Passport case, you have a problem with the cable, the USB interface, or the Passport's power supply.
Regarding the firmware updater: It is not for the plain-Jane Passport Essential model (WDMExx3200). The program should be saved and run from your computer's internal drive, not the targeted Passport drive (the drive can't do read operations while its firmware is being updated).
Oct 29, 2010 | Western Digital Passport 320GB External...
My computer recently stopped recognizing my Western Digital external hard drive. I tried everything and nothing seemed to work so I figured it was the ciruit board. I removed the hard drive and opened up...
Unplugging the CDROM didn't cause this issue but installing the western digital on that cable did cause your drive numbers to change in BIOS. You need to disconnect the external hard drive from the SATA cable but leave the power connected,then boot windows. Once booted reconnect the SATA cable. Check and see if it shows up in your disk management utility.
To do this, right click on computer, then left click manage. When the management console opens, click Disk Management on the left side and scroll down through your drives. Let me know if it shows up and what it says about the partition on the right, I'll keep my eyes open for your reply.
Chris
Oct 05, 2010 | Western Digital Computers & Internet
I cant open the program it says incountered an error and needs to close and the and the Icon blinks
Either the program was not installed properly or it became corrupt after the installation.
Try reinstalling and see if that helps.
Jun 18, 2010 | Western Digital My Book Essential Edition...
Lost my software to install my WD 320GB,what can I do?
Go to western digital.com and download your product software.
Jan 16, 2010 | Western Digital Elements powered by WD 320...
Cant use my external HD
yes you need the cd. you will have to go to western digital support and get the cd
Dec 27, 2009 | Western Digital Elements powered by WD 320...
Drivelock hdd bay password
Hi
This drive may have been used before and may have had a password set on it. If it is new take it back and exchange it
Cheers
David
Jun 21, 2009 | Western Digital Scorpio 160GB Internal...
Trying to partition internal hard drive, taking along time!
Windows 98 thru Vista will partition format the hard drive during installation. Starting with XP, it can handle partitions over 1GB (1000MB).
If it is a new drive, let windows do a "quick format" during installation.
Jan 09, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Western Digital Caviar SE16 (WD5000KS) (5000KS20PK) 500 GB Hard Drive Logo
174 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
