Bose Acoustimass 10 Series IV Home Entertainment Speaker System - White Logo
Posted on Sep 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which model of amplifier will match the Bose AM 10 series4
Steve
Level 3:
  • Bose Master 3,290 Answers
  • Posted on Sep 14, 2010
Steve
Bose Master
Level 3:
Answers
3290
Questions
Helped
1128046
Points
12184
There's a pretty decent write up for this speaker system on CNet. The "Speaker System" section calls for an amplifier capable of 10 - 150 watts RMS.
Bose maintains a library on their products as well. You can download FAQs, Manuals and Product Information easily. On the accessories tab, Bose lists an Onkyo receiver for $350 that will work very well with this speaker system. Of course, any quality modern stereo receiver or amplifier with power in this range 10 - 150 watts should provide good results, but better amps will be in the 75 watts and greater range.
I hope this helps - good luck
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
2helpful
2answers
2answers
The Tone Match unit is not receiving power
If you are using the Bose ToneMatch cable (black cable - the connectors are round barrels with square connectors). Then this should work fine.
If it doesn't then try a different cable. You can use a network Cat-5 cable.
Note - if you are connecting to an L1® Model I or L1® classic then you need an T1 Power Supply.
T1 ToneMatch Audio Engine power supply tone-match-unit-not-receiving-power-l4qeg2fyniuwsgnfiobf0ph3-1-0.png
How to wire Bose sub-woofer to Yamaha receiver
You did not mention the model of Bose subwoofer or Yamaha amplifier.However,depending on the speaker output,most amplifier works seamless with every non-powered Bose subwoofer.
Sir my speaker bose 301 series v and i connect to amplifier pioneer 5 x130 watts.also i have center speaker.bose vcs10.is this compatible to good music and movie....
If they're all Bose 301-5's then you have the rare instance of matching speakers all around, so when sounds move around the room in a movie they don't change. I'm envious because even though I have Bose 901's (front) and 301's I don't have that exact match you have. The 301 sound is very good to my ears.
I assume you have them all set as LARGE speakers in the Pioneer, since they are capable of good bass and the parameter is more about Bass response than actual size.
If you added a subwoofer (which you may not need) you might fill in the lowest bass and effects channel.
1helpful
AVR-1910 & Bose Lifestyle 35 setup
Bose Lifestyle (and all Bose-amplified speaker) products and their speakers are SYSTEMS and should not be split up or intermixed with other brands or models. Damage will probably result. Proprietary connectors provides a clue.
The digital audio out should work with the Bose. You could still use your Denon to drive a conventional sub in your scheme, but you would have to manually match volume with the Bose. Or go Full Monty and buy a full complement of speakers for the Denon, retask the Bose and slave its sources to the Denon.
Hi to double check
Not sure what you're asking. Can you restate the question with no typographical errors?
I can think of no reason why Bose 901's and this, or any, good amplifier would not be a good match as long as you have the Type VI Active Equalizer that goes with the speakers. I would connect the Active EQ where the Pre Out2/Main In jumpers are.
What kind of amplifier and other accessories are recommended for bose 901 speakers
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
