Question about GE 46GW947 46" Rear Projection Television
TV shuts off.
TV just shuts off after a few minutes. If you keep trying it is more frequent. It's like its loosing a power latch on or something. Last time it came on it looked like the bulbs were not aligned.
  • 14 Answers
You need to replace your color guns, realiging them will not help.
Posted on May 16, 2008
My tv shuts itself off!
Quite a long "description". "How can I fix it without having to check the back of the TV or going to a repairman?" (I altered the spelling etc a little there.)
Answer: Go to the internet and search for "Magic TV Repair Wand" and let me know if you find one---
Apr 28, 2012 | Emerson Televison & Video
Sharp Aquos LC-C4654U The TV blacks out frequently. The blackouts last aprox. 1-2 sec and when the picture reappears, the blue box appears in the top right corner (just like when the tv is initially...
Good day!!! That problem is cause of faulty capacitors on the power supply... just look at the actual image of it through visual check if the capacitors look like leak/bulged on top you need to replace it to end that problem... hope it helps... \thanks for using fixya..
Sep 13, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
My Sony Wega, model# KDF-E60A20 keeps shutting off for minutes at a time. The green power light stays on , no flashing. A few seconds before it turns back on ther is a click and a power up sound. Does...
Just replace the bulb first. They last a long time, but after a while if they don't simply blow, they will start to shut off for short periods, then restart. The odd thing is the whole set shuts down too, so something else also may be happening, maybe to do with the temperature control circuitry, that causes a full system shut down. My TV repair man said try this first before I bring the unit in for a diagnostic. Transporting them is not an easy thing to do, given the size of these TVs. I originally bought 3 extra bulbs in 2005, and now used up the last one, and I use the TV a lot.
Apr 25, 2011 | Sony Televison & Video
Mitsi CS-40503 turns on then off after viewing a while
loose connections on the power board,electrolitic capacitors is leacking.
Jul 02, 2009 | Mitsubishi CS-40503 TV
TV keeps shutting down.
the power relay contacts are burned replace the relay
May 21, 2009 | Philips Televison & Video
Speakers emitting a buzzing sound too frequently to ignore
There may be some sort of electrical device like a mobile phone or something that is near the base unit of the speakerset... try clearing the space around them.. or else it might be cuz of a loose connection... check n reseat all the cables & hopfully the problem will sort out...
Feb 11, 2009 | Inland ProSound 2000 Computer Speakers
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
I have a a insignia lcd tv model ns-27lcd turns off by itself
The problem is most likely the fuse connected to the power wires. You have to take apart the TV and follow the power wire to the fuse. Fuse number is T4AL/ 250v. It will be labeled above the fuse. We had the same problem. Also, check to see if the metal around the tops and bottoms of fuse are loose.
The way we fixed it was to wrap aluminum foil around the fuse and put it back in. It is only a temporary fix until we can get a fuse. Hope this helps.
Aug 07, 2007 | Insignia IS-LCDTV32 32 in. Television
GE 46GW947 46" Rear Projection Television Logo
80 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
