Question about Garden
I have a MDT 42", 16.5 horsepower engine I purchased used. It runs great but when I put the cutting deck down it doesn't seem to turn the blades right. I put it up on blocks and felt the blades and one spins very easy and the other is very tight. Is that the way its supposed to be? When I have the mover deck down it seems to shake so I'm not sure if it's a bent blade or if there is a grease fitting that the blade attaches to that needs to be changed. What do you think?
  • 472 Answers
It has a bad pulley on it
Posted on Sep 14, 2010
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
I have a poulan 38" mower. Something seems to be wrong with the deck. The left side cuts great, but not the right. The right side seems to beat the grass into submission. If I back up over the same path I...
check mower blades for blade upside down. you may be hitting grass with back of blade. match blade position to working blade side. or swap blades left to right and see if problem moves. if so, blade is culprit. also cold be a loose blade bolt allowing the shaft to spin without driving the blade. Do all work with engine off key out!
May 16, 2013 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Sears Craftsman rider mower bought in 2001. Still runs really great. However, lately it will not cut the grass when I lower the deck to positions 1-3; the blades seem to stop; no cutting action at all. As...
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Jul 23, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Need 2 know best way to put belt for blades on 46in cut stateman
I use a mdt and I have found that if you put the belt on the spindles first then the tension pulley and last the engine.When it is time to put it on the engine pulley I turn it slowly by hand and it goes on kinda easy.Make sure to unplug the spark plug before you turn the engine pully
May 10, 2011 | Mtd LAWN MOWER PART # 983-04053-0637 DECK...
I have a used Cub Cadet Model #144-664-100 that I purchased last year and used half of the summer and ran great but towards the end it wasn't cutting very cleanly. So I took off a mower blade, which was...
Have you tried running it with the blade back on? It may be ok as there is a braking system built into the pto clutch that makes the blades hard to turn by hand. Regards Phil
Apr 15, 2011 | Cub Cadet Lawn Mower Deck Drive Belt...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Blades slow down when cutting deck is lowered.
the lowerer the deck the more your working the mower. either mow more often or reduce speed
Oct 22, 2009 | Garden
My zero turn mower's deck was knocked off. I put
if it got knocked off, i'd guess it hit something pretty darn hard. i'd check first for bent blade[s], then bent or broken mandrels
Aug 23, 2009 | Garden
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
