Question about Jl Audio 300/4 Car Audio Amplifier
Capacitor digital display shut on then off
I Have 1000 JL amp and 13 JL sub and 2 caps the one 1.0 audiopipe digital display was saying 12 to 11 and then the cap just shut off and then a little later the digital part came back on then it went off again in the same day and wont come on anymore is it that its blown fuse or cap or not charged or not enough charge for the system?
  • 631 Answers
It sounds like you have either a dead battery or a bad connection in the power supply line from the battery. A blown fuse can cause the voltage to drop. This is fairly common with glass fuses in fully enclosed fuse holders. You need to use a multimeter to see where the voltage drops between the battery and the amp.
Posted on May 17, 2008
I have a 1000/1 amp running two W6s in my truck along with a 300/ going strictly to my highs, i also have a capacitor for 1000 that only runs for the 1000/ amp and a JL audio 100 amp fuse for all of it....
You need to get another capacitor and wire it in series with the fist cap when you crank the volume your system is not getting enough power from the alternator this is called surge current. In modern electrical systems we use capacitors to compensate for these surges.
Mar 05, 2011 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 feedback tone
your aux cords could be craked or cut somwhere
Jun 07, 2010 | Jl Audio 1000/1 Car Audio Amplifier
POWER ISSUES
Recomend installing a capacitor, this will control voltage drop and reduce heat. The new battery should help, but it also may be that the amps final circuts could be wearing out, and no longer able to handle the load of the sub.
Sep 28, 2009 | Jl Audio 1000/1 Car Audio Amplifier
What would be a better amp for my jl audio 12in w6v2
its not the amps my dude ur ohm loading is wrong if u have a 4 ohm stabled amp n ur speakers r 2 ohms naw thats not gonna fly caus it cant put out what ur asking 4 so u need 2 reload ur subs try this link http://www.bcae1.com/spkrmlti.htm this should help u out n save u money
Jun 17, 2009 | Jl Audio 12W6v2 Car Subwoofer
Will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
The JL 1000/1 will power the Orion HCCA OK.
It is stable only to 1.5 ohms so your best choice would be the 15.4 with dual 4ohm voice coils. In parallel, this would offer a 2ohm impedance. The 15.2 could only be wired for either a 1ohm load (too low) or a 4ohm load (less power).
Hope this helps.
May 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio amp 1000/1 fix
IVE HAD 2 JL 1000/1S DO THIS TO ME EACH TIME ITS TURNED OUT TO BE A SHORT IN THE RCA IMPUT BUT ALSO CHECK YOUR RCA CABLES AND THE SUB INPUT ON YOUR HEADUNIT
Dec 22, 2008 | Jl Audio 1000/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
Battery
First off, are you trying to stop lights from dimming? Because a capacitor is only a band aid to solving that issue. If you are using a capacitor for its intended purpose (to smooth out the voltage input to the amp, thus providing a more consistent voltage level), the general rule is 1 farad per 1000 watts rms. I hate to tell you caps aren't worth it, but this amp is a good amp. There are built in capacitors already. If you really want to see an improvement in your system, you will want a quality cap along side a quality amp. Look for an Alumapro capacitor. They go all the way up to 50 farads. High in price, very high in quality. Perfect compliment to an amp such as yours.
May 09, 2008 | Jl Audio 1000/1 Car Audio Amplifier
JL Audio 1000/1 power LED is On But no Sound
my amp did same shit, its the rca cabbles, check them out at the back of the head unit. the input jack is probably bad on the head unit
Dec 31, 2006 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 300/4 Car Audio Amplifier Logo
138 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
