Question about Sony Playstation 3 (PS3) Console
How can i connect mobile modem to ps3 - Sony Playstation 3 (PS3) Console
  • Alex Edoh
    Alex Edoh Sep 14, 2010
    this depend on the kind of port your modem operator works with.is it usb or telephone port?
Easiest way is to buy a 3G router like a Cradlepoint CTR350. Then connect either wired or wirelessly. Otherwise you need to enable ICS (Internet Connection Sharing) on a Windows machine and run an ethernet cable from your computer to your PS3
Posted on Sep 14, 2010
2 Suggested Answers
babygenius55
  • 96 Answers
SOURCE: ps3 network issue
First, wire your ps3 directly to the modem, cycle (reset) everything then try the normal connection procedures. You should only have the console, and the modem in the equation for testing purposes, this will let you narrow down the problem. You must turn everything off so that all of the information on both ends will auto refresh.
Posted on Dec 16, 2008
Connecting to matchmaker server is not working
Try resetting your modem and PS3's internet connections..
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Can i hook the ps3 up through a wireless modem i got through my cell phone provider?
yes thats what i use . i use the 3g mobile modem and once i found the best reception indoors it works fine the only trouble is if you leave your mobile within a metre next to it and you get acall it will knock your signal and lose connection but easy to fix dont leave your phone that close to it
Jun 20, 2010 | Sony Playstation 3 (PS3) Console
Cant connect to internet
If you are using a router, the problem probably has to do with the router. In order to find out, disconnect your PS3 from the router and plug it directly into you modem. If your modem is not near your playstation 3 then move it close to the PS3. The modem plugs directly into your cable line so there is a good chance that the television you play your PS3 on has a cable connection. One you have connected your PS3 to your modem, press the reset button on the modem. Turn your PS3 on and go directly to your network settings. Click on Internet Connection Test (do not bother trying to set up a connection manually) If you are getting a connection then you are ready to go.
May 04, 2010 | Sony Playstation 3 (PS3) Console
How to connect my motorola surfboard sb5101 cable modem ot my ps3
Hi turn both modem and PS3 off. Then connect the ethernet cable from the modem to the PS3 and then turn the PS3 first. Then after the PS3 is completely on, then turn the modem on so the PS3 will get the modem's IP adress.
I recommend you get a router and connect it to the modem and the PS3 to the router. It's way better. I hope this helps.
Apr 29, 2010 | Arris SURFboard SB5101 Cable Modem
I am unable to connect to the internet as it is not accepting wep code
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
Connecting my ps3 with a wireless modem
ok you will need a ethernet cable connected from your pc/laptop to your ps3
1st you will need to change sharing settings on your o2 modem
to do this goto manage network connection in there right click on the o2 mobile connection go down to properties go in to properties in there go to sharing and allow other users to use this connection.
2nd when setting up the ps3 you need to change one setting.
on the ps3 go to network settings go dowm to internet connection settings
select costom >wired connection >auto detect> ip adress = automatic >
dhcp = do not set > dsn = automatic > mtu = manual set this to 1420 >proxy sever = do not use > upnp = enable . that it just test your connection .this works good for me wit o2 the only setting changed was the mtu any thing between 1400 to 1450 will work fine ps add lostxbox as friend in psn
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Ps3 network issue
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
How to connect my usb modem to the ps3
Recommendation:
Get a Modem and a Router in order for both computer and PS3 to be online at the same time.
PS3 assumes that it is connected to a router/gateway and is not designed to have a modem directly connected to it as would need additional hardware/chips incorporated.
Nov 08, 2008 | Sony Playstation 3 (PS3) Console
Zyxel p660hw wireless problem
I forgot my modem wireless password...and I can not make a connection without cable...
Jul 12, 2008 | Zyxel P660HW-D1 Router
Sony Playstation 3 (PS3) Console Logo
137 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
