Question about Ryobi 18-inch Electric Chainsaw Chain Saws
Have the Ryobi RY43006 18" Electric Chain Saw. No where in the manual does it state what type of oil to use. ??
  • 11 Answers
SOURCE: What type of oil can
I would use a high quality Bar and chain Lube, available at any saw shop, (My choice is Stihl) If you go other supplier make sure it has anti-sling properties, as this stuff is worth the difference in chain and bar life.
Next time you get some rub between your fingers and slower pull apart, and watch how it clings together, compare different brands and regular motor oil like this and you can tell a difference.
We used to watch how the oil would come off the bar while it was running, cheap stuff in drops and good stuff in what looked like tiny threads.
Thats when we had manual oilers and could pump it out.
Do not use used motor oil as no antisling properties and even on the can it says "used oil causes cancer" You do not want to be vaporizing this stuff and breathing it.
But check manual to be on safe side, but I wouldn't expect otherwise.
Bill
Posted on Jan 19, 2009
  • 42 Answers
SOURCE: Ryobi 18" petrol chainsaw won't start
my guess is that you have a crack or a hole in one of your fuel lines. this is very common in chainsaws and weed eaters because they are used very little and sit for a long time. try checking this and repair if necessary. let me know if this works.
Posted on Mar 08, 2009
Curt_W
  • 60 Answers
SOURCE: chain came off 18 inch ryobi chain saw
Look at http://lawnandgarden.owneriq.net/manuals/mfg/ryobi/ryobi_chainsaw_product_list.html
Posted on Apr 27, 2009
  • 188 Answers
SOURCE: what type of oil do i use in my remington 3hp electric chain saw
According to the manufacturer... Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil.
Posted on Jul 08, 2009
dontbother10
  • 2220 Answers
SOURCE: What is the gas to oil ratio for the Ryobi 10532
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Oct 19, 2009
Need manual for ryobi chain saw cs1800
Try Googling (Ryobi)(cs1800)(manual) without parens.
Jun 02, 2017 | Ryobi Garden
What oil does the ryobi use
all oil tanks on chain saws take Bar/chain oil this can be bought same place u buy 2 cycle engine oil most times , this bar chain oil most times is a 30W oil , if you change weights of oil then oil pump is not gonna add proper amount of oil to saw in use ,this will cause u problems !
Jan 18, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
Oil not feeding to the chain guide on the electric ryobi chain saw
Remove the cover on the right hand side of the saw and remove the bar and chain. Clean the oil port holes in the bar and the body of the saw. They get clogged with sawdust and chips. Also clean the groove in the bar and the sprocket at the end of the bar. Always use proper chainsaw bar oil.
Jan 12, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
Bought a Ryobi cs214 at a pawn shop. There is no oil in the holder for smooth running of the machine. Would like to know what kind of oil does the Ryobi CS214 takes.
Just fill the tank with regular bar/chain oil available at home centers, hardware stores, and saw dealers. Don't use old used motor oil or similar. Hope this helps!
Dec 21, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Where are the oiling ponts to the bar to the ryobi 16 inch petrol chainsaw?
Hi
It's Lisa?
On an electric chainsaw there usually aren't what you would call oiling points.Somewhere,probably on the rear or one side of the case will be a bulb.It's also the screw on cap for the oil reservoir.
You fill that up with chainsaw bar oil,and as you use the saw every few minutes push the bulb down 2-3 times and it applies oil to the chain and gear in the case.The chain transfers the oil to the bar.
If this helps,would you rate my post please?
Thanks Bob
By the way,if you give me your model number I can look for a manual somewhere.No promises though,Ryobi likes to sell their manuals rather than download them.
Aug 16, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
I bought a ryobi 14 inch electric chainsaw. Is
Use regular bar/chain oil available from home centers, hardware stores, and saw shops. Always keep the chain properly sharpened and tensioned so that you don't have to force the chain into the cut which causes motor overheating. If you need to make an 'under' cut, do so with the top of the bar--don't run the saw upside down. Good luck!
Jul 30, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi ECW 1836 electric chain saw. No drive
Check to be sure your chain brake is in the OFF position Pulled back towards the operator
Apr 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Need to know what kind of oil to put in ryobi chainsaw
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
Jul 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
What type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Mar 13, 2009 | Remington 16" Electric Chain Saw
What type of oil can i use for an electric chain saw? It's an 16" Eager ******.
Bill
Jan 19, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
195 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
