Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
Posted on Sep 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have (had) the Poulan Pro 25 cc trimmer. The motor and main shaft have been nothing but problems for me. I still have the attachments. Do you know if there is a way just to buy the main shaft/motor? Thanks thanks
Roy Cagle
Level 3:
President:
  • Poulan Master 1,545 Answers
  • Posted on Sep 14, 2010
Roy Cagle
Poulan Master
Level 3:
President:
Answers
1545
Questions
Helped
913224
Points
4781
Sure you can...that would be called the crankshaft assembly. You can find it here...along with any other parts you may wish/need. These low-end trimmers are practically considered disposable household items nowadays and a lot of people treat them as such. Look for the crankshaft assembly here:
http://www.ereplacementparts.com/poulan-pro-pp125-gas-trimmer-parts-c-16962_17820_18351.html
I am a little surprised at the lower cost.
Saw attachment will work but weed trimmer attachment will not turn
check that the trimmer attachment is fitted properly on the shaft as it appears the the shaft drive is not engaging in the head
Poulan trimmer drive shaft attachment problem
Square drive on the end of the drive shaft has to line up with the drive on the output of the clutch.
Does my poulan pro pp428S use oil in gas
No it is a 4 stroke and doesn't require oil to be mixed in the fuel. It does require at least 90 octane.
3helpful
My poulan pro trimmer has no nut on the head to remove it. it has a screw inside. how do i work that. the screwdriver wont hold it.
See page 13 of your manual here for removing the head. Please realize that the head has LEFT_HANDED threads on it (not the conventional R-handed) so you have to turn it to the RIGHT to loosen and remove it.
http://dl.owneriq.net/0/025d5114-7fc1-41e0-8faa-5205f15e8cf5.pdf
Fuel mixture for poulan pro heavy duty brushcutter 331 sn 01254n500330-1is needed asap. lost my manual!!!!!
40:1 mix, 3.2 oz of 2 stroke oil for every gallon of gas.
Link to the manual is below
http://www.poulanpro.com/ddoc/POUO/POUO2001_USen/POUO2001_USen__530088910.pdf
8helpful
2answers
How do you change a head on a poulan pro trimmer
Just below the gearbox there is a slot and when you turn the shaft there is a slot on the shaft that lines up with that one. Stick a screwdriver in the slot when they are lined up and then grab the head and turn it clockwise. (the threads are reversed)
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
