Question about Sony Mavica MVC-FD90 Digital Camera
Format disk error C:13:01 - Sony Mavica MVC-FD90 Digital Camera
When i want to open my D drive ,it gives this masage 'the disk in drive d is not formatted. do you want to format it? yes or no' . i don't want to format it. what shoud i do?
As you know already that format disk basically creation of FILE ALLOCATION TABLE (FAT) NTFS (new technology file system)
it is necessary to store data on disk. but if this error occurs while disk already formatted with any file system then simply run disk repairing utility to fix the problem
If its intel based machine or AMD and running windows then i would recommend run scandisk utility
if its mac run disk utility from utilities and check disk for any error and it will repair the disk
good luck
Aug 19, 2011 | Computers & Internet
My Maxtor Athena 20GB hard disk is in error
delete the entire partition and do a quick format....
then do partition according to your requirement and try formatting...
if it still says error, then use any disk formatting utility like partition magic and try one more time....
still problem then you should take it back for replacement if it comes under warranty period....
Apr 20, 2010 | Maxtor Hard Drive
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Checking hard disk for errors
no, checking the Hard Disk using windows tools does not format the hard disk. You data would still be there.
Jul 20, 2009 | Computers & Internet
Format error
format ur card on PC change the card
Jun 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I am unable to access my teac FD-05PUW usb floppy disk disk drive it come up in my computer as disk B but when I try to assess the drive it tells me the disk is not formatted but when I attempt to format...
Solution 1.
Try using the Installation CD or Utiltity CD that came with your drive to format it.
If theres a Utility CD then install it on your computer and try formating it from the utility application.
If the windows error messages still persist then try formating it with the windows default options or NTFS option.
Apr 26, 2009 | Teac FD-05PUB External Floppy Drive
Disk is asking to be formatted - already been in use
this could be a help to you,first off most,cds, and memory disk,get scratched or worn out,that causes errors or corrupt file readings. so thats why it asked you to format,formating helps clean the drive up,like a tune up on and old car.and if you dont and try to put high grade gas in before the tune up your still going to have the same problem,so in saying you have to put the old one back in,format it. and then put the new one in after you completed formating the old one.good luck,hope that helped you.
Mar 22, 2009 | Kodak EasyShare C330 Digital Camera
Disk error problem
when u start computer press F8 key then u see safe mode.enter in safe mode.then type "chkdsk /r" in run then press enter then press "y"
then restart the computer then it checks the disk for error if any error on that it fix the errors,.
Mar 16, 2009 | HP Computers & Internet
Reguarding the ps2...
please tray your ps2 disc format pal with another ps2 console if still can play game sure your disk err
Jan 12, 2009 | Sony PlayStation 2 (PS2) Console
Mp4 player defect and disk error
initially,i was experiencing format error when i tried to open somefiles but i tried to format the player using windows, but i guess itmessed it up because i started having disk error2_bing.gif messages. Now, i canteven use the mp4player or look for a possible way to reformat it. iahev even tried mp3 utilities disk tool but it didnt work. Please helpme the firmware version is 2007/02/14 9.1.51 7515_2.2TFT 2007/01/25
please help
Jan 06, 2008 | Audio Players & Recorders
Sony Mavica MVC-FD90 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
