Question about HP Color LaserJet 3500 Printer
WHY IS THERE A YELLOW LINE DOWN THE RIGHT SIDE ABOUT 1/2 INCH WIDE
    Genius:
  • 1,089 Answers
Change the yellow toner cartridge
Posted on Sep 14, 2010
How do I make a large buttonhole ..( 1 3/8 inch).. the button doesnt fit on the buttonholer.
You do it using narrow rows of side by side zig zag stitches and bar tacking the ends of the rows. Make a line where you want the hole to be. Set the zig zag stitch width very narrow, whatever is closest to what suits the fabric. Coarse or loose weaves need a wider width, finer ones a narrower width. Experiment on some scraps to get it right. Number of stitches per inch, or stitch length, should be very fine, at least 20 per inch, but not 0. Try a few more experiments on scraps to make sure it looks right. Make a test hole to be sure it is the right size for your buttons.
Stitch a straight line of zig zags down one side of your line, with the edge of the stitching not quite touching your line. Stitch a second row directly on top of the first one.
Repeat on the other side of the line. Ideally you should still be able to just see the line you drew when the rows are done, but not see any bare fabric on either side of the line.
Then move to one end of your rows. Leave the stitch length the same, but change the width to match the width of your two side by side rows. Stitch a bar tack, about the same length as your two rows are wide. If your two rows are 1/8 inch wide, your bar tack should be 1/8 inch long. Do the same at the other end. Make sure the bar tack covers the very end stitches in the rows as it is the anchor that will prevent unravelling. This is exactly what machine buttonhole makers do, but they do it all for you.
Carefully slit between the rows to open the hole. I like to put a drop of Fray Check or something similar on my buttonholes after I cut them open. It makes them much stronger and they will never come out.
Oct 09, 2014 | Sewing Machines
Mutiple lines on right side of photo
try removing the ink cartrage and clean the heads in the printer with a quetip and rubbing alcohol. same with the cartrages.
Nov 12, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Vertical Line on Lap Top
One or both of the following:
Your signal processor is failing OR the lcd display panel itself is failing. When one fails it's prudent to replace both.
Jun 04, 2009 | Compaq Presario M2000 Notebook
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Line on screen
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Apr 07, 2008 | Fujitsu Plasmavision PDS-4233 42 in....
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP Color LaserJet 3500 Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
