Question about Canon PIXMA iP6700D InkJet Photo Printer
IP6700D will not recognize magenta ink tank I dunno why they call it a "tank" its more like a vile or a thimble or eyedropper.
  • Anonymous May 23, 2008
    printer will not recognize yellow ink cartridge
  • hamiltongi Jun 18, 2008
    Exact same problem, Will not recognize magenta tank, error code U150, then I receive an error code of 5100. I've tried taking it out & putting it back in, to no avail. I was going to try filling the cartridges myself, but after this problem, with a canon cartridge, I don't think I'll attempt it. I'm so fed up with this printer.
SOURCE: MP500 ink tank cannot be recognized error U043
my mp600 was struck down today (was intermittently doing it, but now permanently) with the Yellow tank doing Error 150.
Phoned Canon (In Australia)
They said they would replace the faulty cartirdge.
Send them (in Australia only) to
Canon Australia Pty LTD
Attn: CIPG
PO BOX 313
North Ryde NSW 1670
Posted on Mar 13, 2008
I had the same problem with a Canon Pixma MP800 here is the procedure I went through to fix it. I removed the new cartridge then taking a clean tissue I gently wiped the front of the ink well were the the electronic chip in the cartridge meets the ink head. I replaced the new ink cartridge and the red light came on. I closed the cover the printer returned to normal working mode!
Posted on Apr 01, 2008
sadguy
  • 88 Answers
SOURCE: Error message U150 appears saying
try diffrent pixma mp970 may be that defcated
Posted on Aug 15, 2008
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Posted on Sep 04, 2008
SOURCE: cannot recognize ink cartridge
I had the same problem. I was using original brand cartridges and it was still not working. Here's how I got it to work. I recommend doing each step and then trying to print a test page to see if it is working.
1. I used a Q-tip with Isopropyl Alcohol and cleaned the gold contacts on both the cartridge and the mating contacts in the printer.
2. Then from the Setup Menu, I found a menu called Tools. From there I ran "Align Print Cartridges".
3. From the same menu I also ran "Clean Print Cartridges"
4. I then ran a few test prints by going into the Setup Menu and then choosing "Print Report" and then selecting "Self-Test Report". It prints grid patterns in black & white as well as magenta, yellow and blue. The black grid pattern had some missing lines until I printed this report a few times.
5. I made a few photocopies and now the printouts no longer have large stripes of missing ink as it did in the earlier steps.
Good luck. Hope this helps.
Posted on Dec 03, 2008
I have a Canon iP6700D. I refill my carts. I have a resetter and use it every time. This time the printer won't recognize the magenta cart. I refilled it, reset it and replaced it as always. I...
If your printer did not good in times of reseting the cartridges do check the cartridge holder if the is some dirt inside or the terminal of your cartridge had wet by the ink when you refill the ink of your cartridges.
Aug 12, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
A canon ink tank is not being recognizd. Previously it was working fine. Then I added a new black cartridge. Now the magenta won't work. All Canon cartridges. Trina
All ink tanks has a memory chip.With this chip the printer recognize the ink tanks and the ink level.Sometimes this chip failed.Just replace the magenta ink tank.
Nov 24, 2009 | Canon Pixma MP950 All-In-One InkJet...
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
The following ink tank
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
PHOTOS ARE PRINTING IN GREEN CONTRAST
Many times that happens when you put photo magenta ink in when it should be plain magenta. Photo inks are not interchangeable with regular inks.
Jul 28, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Alarm light is lit -
Ok my printer is giving me the U140 message saying that ink tank cannot be recognized. The new ink tank is Cannon (not a off brand or refill). i think it is a problem with the chip reader port inside the printer not the ink tank chip. I feel this way because if you switch around the yellow and black 8 tanks, the printer accepts them without error.. soo if it was the ink cartridge i could be able to swap the black with the magenta and it should read it.
Sep 08, 2008 | Canon Pixma MP500 All-In-One InkJet...
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Ink tank recognized
jen, try this clean the cartridge connectors the part where there is a chip. clean with alcohol. and clean also the other side where it connect to the printer head. i hope this will help. i not try to buy an original ink.
Jun 13, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Error U130 Cannon ink tank
it is possible that the ink chip is damage. try to buy another. or you can buy original ink to make sure the printer is ok.
Apr 16, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Ink cartridge lights blinking
That is happening because you have "smart" chips on your cartridges, so even though you know there is still some ink left in the tank, if the chip says stop, the printer will stop printing. There is a way to bypass that and that is by using a re-setter. You can either buy one or ask to re-set your cartridge in a refill shop.
You can also try holding the "resume" button (triangle in circle for about 10 seconds for each cartridge, sometimes doing that resets the cartridges.
Do not refill the magenta and cyan cartridges if they are not empty, you'll just be wasting your money. Better use it to buy a re-setter ;)
Hope that will help!
Nov 27, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
old marine
old marine
