Question about Bosch HME9760 Microwave Oven
Boshe Gourmet Microwave combination oven failure (Model No HME9750GB/03 FD8101). Oven switched on and made a loud bang. Display has now gone blank, with no function of any control knobs/buttons etc. Replaced 13A fuse without a result. However, did notice the display come back to life for a short time and was able to adjust time setting.....the display then faded away to blank. Repeated the process and the same happened again. Any suggestions would be gratefully received. GP
2 Suggested Answers
  • 228 Answers
SOURCE: Microwave combination oven failureHME9750GB/03 FD8106 (/555350)
APPLIANCE HAS INTERNAL 8 AMP SAFETY FUSE IF THIS HAS BLOWN IT WILL NEED MAJOR REPAIRS AND POSSIBLY COSTLY THIS FUSE ONLY BLOWS IF FAULTS EXIST WITH HIGH VOLTAGE SIDE OF APPLIANCE SO NO NOVICE SHOULD ATTEMPT A REPAIR.
Posted on Jun 10, 2010
Why is my microwave model 60609 making extremely loud noise and not heat?
Usually that is a sign that your magnetron tube has gone bad (shorted out).
Jun 10, 2014 | Kenmore 80822 80823 80824 80829 1500...
Microwave gone dead 2nd time
thats easy - ITS WARRANTY - take it back -
Nov 28, 2013 | Microwave Ovens
My Dacor Microwave display is blank so I can see what I'm programming - however the microwave works fine. I think a bulb it out. I that possible and something I can fix? Model DMO 2420R. Thank...
This is a failure in the backlight circuit and/or a display segment failure.
Both are regularly repaired with our $39.95 service. Details are here.
Jul 05, 2011 | Dacor DMT2420SS Microwave Oven
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
CONTROL PANEL BLANK after a loud bang while cooking
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 23, 2011 | Microwave Ovens
Jan 18, 2010 | Bosch HME9760 Microwave Oven
Bosch HBC84K520B Combination Microwave Oven
If you google search bosch gourmet the second item down titled "bosch household appliances" you can download a manual from there
Jun 27, 2009 | Bosch HMB402 Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Combination microwave oven
What is the nature of the failure?
Can you enter cooking the time?
If so, what happens when you press Start?
Does it run (count down, lights on, turntable on ) but not heat?
Brand and model might help, too, but the basics are the same, so we're happy to help you with more information.
Nov 25, 2007 | Microwave Ovens
Bosch HME9760 Microwave Oven Logo
321 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
