Question about Hamilton Beach Eclectrics Coffee Maker - Pineapple Yellow
Cannot find a yellow or red one to buy - Hamilton Beach Eclectrics Coffee Maker - Pineapple Yellow
  • 268 Answers
They are harder to find because they are now clearance items. I think you can still buy one online: http://www.overstock.com/Home-Garden/Hamilton-Beach-40132-Eclectrics-12-cup-Programmable-Red-Coffeemaker/3907264/product.html?sid=8480317&pid=2242988&aid=10654383
Posted on Sep 14, 2010
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
My xbox scartlead wire is 3 coloures yellow white red and my yellow connetction metal piece has snapped off
i had the same thing before two options buy another or get a normal red ,white and yellow vga cable and cut the one part from the other and connect the wires and cover with electrical tape or visit xbox360repairspro.webs.com
May 28, 2011 | Video Game Consoles & Games
Which do i plug red yellow and white into
If you are using the RGB (red, green, blue) and the the red, yellow, and white cables. Then the RGB cables are in place of the yellow, you should plug the cables into a Component input on the tv you are using. The red and white cables are the audio cables and should be plugged in but the yellow will not be used if you are using RGB.
If you have only the yellow, red, and white cables, just match them up with an input on the tv or any player that has the inputs.
If you need a new cable, Amazon sells one along with any local store such as Walmart or Best Buy. http://www.amazon.com/PlayStation-3-Component-AV-Cable/dp/B000MIXFWA
Does this help? If you have further questions, please let me know.
Benjamin
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
Playstation will not power up.red light turns to yellow-amber colour then straight back to red.
It needs to be serviced. It may be better to buy a slim instead, I think its the way of the future.
May 14, 2010 | Sony PlayStation® 3 (80GB) Console
Using the red whit and yellow VCR cables, how do i
You must have a monaural (mono) TV even though it looks like you have speakers on each side. The VCR has stereo audio output red=right white=left yellow=video. Ideally you would buy a mixing tee to add the left and right signal. Or if your VCR supports it you can set it to mono output. Otherwise, just use the white (left) cable to feed the mono input (white) and of course the yellow to yellow for video. Just ignore the red wire or lightly tape over it to avoid any short. Best,
-Ken
Apr 16, 2010 | Apex Digital AT2402 24" TV
Image is showing with yellow & red shades
Ur convergence is dead.Must know how to solders?Replaced convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit.Shop will cost u $300 for parts and labors.
Jan 16, 2010 | Hitachi 61UWX10B 61" Rear Projection...
Black and yellow won't print. Blue and Red are
Your black & yellow catridge has been faulty.So you can buy these catridge for you printer.
Nov 03, 2009 | Brother MFC 210C All-In-One InkJet Printer
Yellow image produced by DP8200x
the light filter on the blue lcd is fried and needs to be replaced. it makes sure only blue light comes therough that lcd panel. when it's light is blocked from coming through, only the red and green lights can be seen, hence the yellowness (red light+green light=yellow light). it's common with lcd projectors. unfortunately, you can't buy that piece seperately. you need to buy the entire optical engine, which isn't cheap (almost $2000).
Jul 31, 2009 | ASK Proxima InFocus Projector lamp for...
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
Hamilton Beach Eclectrics Coffee Maker - Pineapple Yellow Logo
123 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
