Question about GPS
We have a 2005 GMC Envoy that has had an Automate remote starter installed prior to our purchase of the vehicle used. The remote is nearly worn out. Our GM remotes will only work to lock and unlock the truck you HAVE to push the unlock button on the Automate remote in order to be able to turn the key without the security system going off. How do we remedy this problem?
  • 3,287 Answers
Without knowing how old the battery(s) in the remote are, I would suggest that to be the first thing to replace. It is relatively easy and inexpensive to do - and could solve the problem.
You can attempt to pry the remote apart to access the battery(s) after removing the remote from the keyring, or bring it to a Batteries Plus store (or a hardware store) where an employee can replace it for you.
Beyond that, you'll probably have to return to the place of installation of the starter to resolve the issue. A phone call to the installer may be able to solve the problem over the phone instead of having to go there.
Posted on Sep 14, 2010
2005 GMC Envoy XL. Will not engage starter. Like something electrical. Turn key and nothing. Worked fine until now.
Could be the neutral safety switch if it won't crank in neutral or park, could also be the starter has failed.
Feb 22, 2015 | 2005 GMC Envoy Xl
What causes left spider gear only to be chewed up
I need more information to help. What part of the spider gear is it that is chewed up? Was this vehicle repaired prior to this issue? Causes could be: Water inside the housing, low gear oil level, old worn out gear oil, two different size tires on the same axle, worn axle spline, rust or metal debris, improper use of vehicle. Payload was too much and related gearing overheated. I hope this helps, please let me know.
Feb 26, 2014 | 1999 GMC Envoy
2005 GMC Envoy trailer lights
Check the white ground wire on the plug on the vehicle.
Aug 23, 2012 | 2004 GMC Envoy
2005 GMC ENVOY 4.2L VIBRATION PROBLEM AT IDLE AND START UP OR ANY TIME NO ACCELERATING
Hello! This is a known problem that is addressed by the following Technical Service Bulletin...Guru...saailer
Subject:Steering System Moan, Groan, Shudder and/or Vibration Type Noise During Low Speed Turning Maneuvers (Replace Steering Gear) #04-02-32-007A - (12/01/2004) Models:2004-2005 Buick Rainier
2003-2005 Chevrolet TrailBlazer, TrailBlazer EXT
2003-2005 GMC Envoy, Envoy XL
2004-2005 GMC Envoy XUV
2003-2004 Oldsmobile Bravada
Short Wheelbase Utilities Built Prior to VIN Breakpoint 52123375
Long Wheelbase Utilities Built Prior to VIN Breakpoint 56137280
This bulletin is being revised to remove the 2002 model year and add the long wheelbase utilities. Please discard Corporate Bulletin Number 04-02-32-007 (Section 02 -- Steering).
ConditionSome customers may comment on a moan, groan, shudder and/or vibration noise while making low speed turning maneuvers. Customers usually notice this condition in parking lot turning maneuvers.
Correction
  1. Diagnose the power steering concern. Refer to Symptoms - Power Steering System (SI Document ID #670351).
  2. Replace the steering gear with a newly designed steering gear. See the parts information below. Refer to Power Steering Gear Replacement (SI Document ID #742314).
Parts Information
Part Number
Description
Qty
88965356
Gear Kit, Steering
(Short Wheelbase Utilities)
Gear Kit, Steering
(Long Wheelbase Utilities)
Warranty InformationFor vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E9740
Gear Assembly, Power Steering - Replace
Use published labor operation time
E2000
Toe, Front - Adjust
May 03, 2012 | GMC Envoy XL Cars & Trucks
How do you remove the starter off a 2005 GMC Envoy XL V8?
1st, remove the positive lead to the abttery. Next disconnect the wires from the starter one at a time. I recomment you wrap each with a layer of black electrical tape to protect them. After the wring is removed, remove the bolts to any brackets that are attached to the starter and the two large bolts holding the starter into the transmission housing. Remove the starter. Reverse order to install new starter. Test before your close the hood. It isn't very difficult. If you run into problems, ask me, and I will assist you.
Apr 07, 2010 | 2005 GMC Envoy Xl
2005 GMC Envoy. Wining sound from under the car at startup.
I suggest checking your starter motor. If the starter motor is staying engaged it could be a bad solenoid or a bad ignition switch.
I hope this helps.
Roy
Nov 06, 2009 | 2005 GMC Envoy Xl
Check Engine Alert
No not that I could find, before you remove the whole this just pull both fuses on the main harness red wire there should be 2 total, also check to see that the white ignition wire is hooked up to the remote start unit as this is a very important wire that needs to be hooked up because it is tyed in with your transmission system
Dec 28, 2008 | DEI Valet Keyless Entry System
@005 Envoy Wont start when cold
If you can replace your own starter I would buy a new one and try it. Sounds like it could be a worn commutator and when cold the brushes do not make contact with the armature. Worn bushings will sometimes do the same thing. If you are mechanically inclined and have tools I would remove the starter and see if the shaft is loose in the bushing. If so you might try to find a replacement bushing and install it.
Sep 29, 2017 | 2002 GMC Envoy
Programing keyless remote
To Program a new remote you must get in your vehicle, close all doors hold your unlock button down.while holding the button down turn your key on and off two times.at that time your locks will all cycle.Then with your keyless remote hold your lock and unlock buttons till the locks cycle .
Aug 01, 2008 | 2005 GMC Envoy
GPS Logo
81 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
