Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Smtp authentication - bizhub 250
Did you ever get yours working? What version of pagescope do you have on your device?
I've got the same problem and can not find any firmware upgrade option or anything. We must have old versions of the bizhub 250 or something.
  • Konica Minolta Master
  • 2,794 Answers
Firmware can be upgraded by using a 256mb compact flash memory card.
The slot is located on the right side of the machine below the scanner glass. Its in the same area where the fax phone lines plug into.
Posted on Jun 11, 2008
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Bizhub C224 Color Copier /...
Bizhub 282 E73000 error code
CAUSE: With Gmail, the MFP must support SMTP over SSL/TLS. The bizhub 200/250/350 and bizhub 222/282/362 series do not support this functionality.
SOLUTION: An E-mail server that does not require support for SMTP over SSL/TLS would have to be used.
Hope this helps you
Dec 11, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
On C35 bizhun get error when scan to email SCAN TX FAILED JOB CANCELLED any help?
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
Oct 07, 2011 | Konica Minolta Konica Bizhub C353 Drum...
I can set up smtp for out going email but there is no places to enter user ID and password to use the smt. there are user name and password for pop3 setting but not in smtp setting.
There is no need to set user name & Password for outgoing SMTP serve, if you have cliked on "use same setting as incoming server " under SMTP server required authentication.
Mar 03, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Job has been done improperly check log files . Server connect error???
SOLUTION: Set the Administrator Email Address and Device Email Address fields.
1. From PageScope web connection, enter the Admin mode.
2. Select Network, Email, Email Transmission.
3. Enter Admin email address.
4. Enter Device email address.
5. Select Apply
Jul 08, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
User Auth. for Mac on BizHub C250
setting up auth. on mac requires that you open the doc on appropriate app, on print menu select output method, set auth. credentials, and save. then print. some mac OSX ver. will save others won't. prompting you to set auth, every time you need printing.
Aug 26, 2017 | Konica Minolta bizhub C250 All-In-One...
BizHub 250 Printer Driver
Hi, which version of Mac OS have you ? what are your problems ? also, i ve sent the ppd necessary for the Bh250 Mac driver on http://crackzfr.free.fr/bh250.sit. You'll have just to register it on your mac and, you'll be able to print on your Bh...
Jan 06, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Is there a way to upgrade pagescope?
the pagescope is included in firmware, so you must update firmware.
May 16, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Cannot Scan To E-Mail
yes, you can, go to brauser and type your bizhub ip aadress, you'll get a webscope page, there log in as administrator and under network choose e-mailt - smtp and there shold be a place where you can mark, that youre smtp server requires authentication.
May 05, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
HELP
sry, didn't really understand, so you cant print ??? but printing and smtp/pop3 is not bound eachother. reboot printer, reinstall driver, look printer status with pagescope connection.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
668 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
