Question about Invacare Pronto M51 Power Wheelchair
Cannot get chair off. I got the Lock Know off, but chair won't move. the Bolt that the knob is attached to is still in the post of the chair.
  • 692 Answers
Red You don't need to remove the bolt. If u lift the handle under the right side of the seat the seat should turn. Turn the seat a little and pull up on the seat at the same time. the seat should come out of the seat post. Also try twisting the seat as you pull up on it. If it doesn't want to come out after all that then u need to spray some WD40 or other type of oil to get the seat out of the post. They are sometimes very hard to get out cause the post wasn't greased and moisture can cause it to rust. Hope this helps you n GOOD LUCK
Posted on Sep 14, 2010
My quantum 600 wheel chair won't work it says system lock
My quantum 600 wheel chair won't work it says system lock ...
www.fixya.com/.../t26033304-quantum_600_wheel_chair_work_says_s...
2 hours ago - My quantum 600 wheel chair won't work it says system lock -Wheelchairs question.
Pride Mobility Quantum Q6 Edge (Power Wheelchairs ...
www.usatechguide.org/itemreview.php?itemid=1626
Quantum 6000 or 600 Rehab Power Wheelchair - CareCure Communitysci.rutgers.edu/.../showthread.php?...Quantum-6000...Rutgers UniversityJul 4, 2008 - 10 posts - ‎9 authorsI had the QUANTUM 600e Rehab Power Wheelchair for six months. ... C-500 Hvy dutypower chair w/hi-speed motors, power seating system, .... I have a Q600 with tilt, recline, leg extension, Q-logic..pretty much the works. ... the thing shuts itself off andwon't move when I have anything under 90% charge?Quantum® 600 Power Chair Reviews - Pride Mobilityownersclub.pridemobility.com/reviews/item/1/20The Quantum® 600 Power Chair delivers the stability of patented Mid-Wheel 6® ... At that same time the 3rd motor set was changed my seating system was ... We were rescued by boat and my friends say the wheelchair was working ... Insurance won'tcover a power chair for me yet so I had to pay out of pocket for this one.
Jan 01, 2016 | Health & Beauty
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
HOW DO I FIX MY OFFICE BOSS CHAIR IT LEANS BACKWARDS AND WON'T STAY STRAIGHT
without sounding like a smart ***, have you checked the adjustors under the seat. Some handles are 3way handles and can do multiple adjustments. If you have adjusted all the knobs and handles, maybe it is leaking gas or in some case oil. Some of these chairs have an extra knob at the back of the seat along the column of the back rest, as to lock it in the desired position. Good luck.
Jun 01, 2012 | Furniture
I have a babylock 1556 and when I press the foot petal the belt turns, but it won't move the needle up and down. I took off the back so I could watch and see what was going on. I can see the belt...
On the side of the 'knob', look for another wheel that tightens against that, so it engages, that's what it sounds like. When that second wheel is loose, it won't run, it just spins. From the photo I can find of the unit, it looks like that second wheel is below it, but I can't be certain. Let me know how you make out. Please rate and comment, thank you,
Joe
Sep 04, 2011 | Baby Lock BL1556
How to remove the seat of a prono wheelchair
Hi. To lift of the seat, you need to pull the knob under the side of the seat that allows you to turn the seat. While you are pulling upward on this lever, use your other hand to lift the seat of its mount. This might be hard to do if the seat pivot is lacking any lube or a light film of oil.
You might have to disconnect the cable to the joystick control first.
Good luck. Neil.
Aug 23, 2011 | Invacare Pronto M51 Power Wheelchair
I BOUGHT A USED JAZZY JET 3 ULTRA WITHOUT BATTERIES AND I HAVE BOUGHT 2 NEW BATTERIES BUT AM NOT SURE HOW THE WIRES HOOK TO THEM, IF THE 2 BATTERIES HOOK TOGETHER.
Locate the two wires from the circuit breaker attach one wire (black if marked) to the negative post of the rear battery and attach the other wire (red if marked) to the positive post of the front battery. Locate the two wires coming from the power module plug with a red and black wire. Attach the red wire to the rear battery positive post and the black wire to the front battery negative post. attach the joystick to the nine pin plug at the rear of the chair and turn it on. You should have power at the joystick and the chair should work. Disconnect the joystick put the shroud cover back on grease the seat post and reattach the seat then plug in the joystick and charger plug at the rear of the chair. Charge the batteries before use and charge them overnite for the next 20 days. If you use the chair daily charge your batteries everynite while you sleep unplug in the morning. If you don't use the chair daily charge at least once per week or after you use the chair. Always put the chair up fully charged if you are going to be out of the chair for an extended time the disconnect the batteries at the large plug going to the power module Hope this helps you
Apr 13, 2011 | Jet 3 Ultra Power Chair
Want to get back of chair off the chair
If its a regular office chair then the solution is fairly easy...
Look underneath the chair and there should be a bolt or two screws holding the 90degree arm that the back is attached too. Remove those and you'll have it in two pieces.
Sometimes office chairs have the 90 degree arm attached to the base. In this case you would need to look under the base for the main bolt. Remove that and then the spring inner pole should slide out. From there simply disassemble the reminder bolts.
I always keep track of where the bolts and/or screws go, because when you go to put it all back together it'll make the job much easier. Draw a diagram if needed.
Side note, if you could provide what brand of chair this is I may be able to assist you further, the above is just general knowledge.
Feb 21, 2011 | Office Equipment & Supplies
The rear passenger door on 1993 lincoln contenental will not open neither from outside nor from inside but the pin goes up and down when operated by fob as well as unlock - lock button on the car
Ok this one is a tough one. If your handle on the outside does not work for some time, then the rod that attaches to the handle has most likely come loose. Your options are limited. I usually do not recommend the use of a slim jim. However in this case, a slim jim is an option. Inside your read door panel are three main rods. One rod moves the inside handle. The other rod moves the outside handle. The third rod is attached to the lock knob. Using the slim jim slide it into the door. Hook it onto one of the rods and pull up slightly. Try to see what is moving when you move the rod. If it is the inside handle or lock knob is moving, then find another rod that moves nothing. That will be the rod that should be attached to your outside handle. Lift up on that rod and it should open your door.
After you open the door, go ahead and take the time to fix your door, by removing the door panel and re-attaching the rod to the handle.
Let me know if you have any further questions.
thankyou for using fixya.com
Jan 21, 2011 | 1990 Lincoln Continental
Looking for a guide to install a driver side window motor
Good day
this going to be a long one I'll start with water deflector
WATER DEFLECTOR
1.remove trim panel
2.remove seat belt assembly
3. remove tape from deflector and door inner panel
4. remove deflector from inner door panel using a wide flat bladed tool to break the hot melt sealer bond
TRIM
1. remove the power door lock switch from the trim panel
2. remove lock knob and bezel
3. remove screw and reposition or remove the remote mirror bezel
LOCK KNOB AND BEZEL
1. remove cover
2. remove remote control bezel retaining screw
4. remove knob from lock rod by prying with a flat bladed tool
4. remove knob
5. remove bezel
SWITCH
1. remove switch from trim panel using a small flat bladed tool
2. disconnect wire connector from switch
POWER MOTOR
1. remove water deflector
2. raise window to fully up position and tape window to door frame using cloth backed body tape
3. punch out the center pins of the regulator rivets then drill out rivets using 1/4 inch drill bit
4. move regulator rearward and disconnect wire harness from motor disengage roller on regulator lift arm from window sash channel
5. remove regulator through rear access hole
6. secure regulator arm to regulator by inserting a bolt through holes in the regulator and sector gear then attach a nut to the bolt
7. using a 3/16" drill bit drill out motor attaching rivets and remove motor from regulator
INSTALLATION
1. install motor to regulator with 3/16" rivets or 3/16" nuts and bolts
2.remove nut and bolt securing regulator arm to regulator.
3. then install by repeating the removal
hope this helps it's not as hard as it reads
Cheers
Jul 13, 2009 | 1992 Chevrolet Cavalier
Invacare Pronto M51 Power Wheelchair Logo
100 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
