Question about Kenmore Dishwashers
Kenmore Elite 17473300 dishwasher. How do I remove the control panel? It's on the top of the door. It got doused with hot liquid and warped.
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console4.gif. It is a small silver colored device4.gif attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like that, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacement kit (found at most appliance repair stores) that had thicker wires. The part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at repairclinic.com. Order on line and have the part shipped directly to you. Now...to access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even though the dishwasher is not running, the control board still has live voltages present.
2. Open dishwasher door and remove the top screws that hold the console in place. You shouldn't have to remove the lower screws unless you plan on removing the entire door panel.
3. The control panel should pull off from the front enough to where you can access the control board. There is a thermal fuse mounted on the board with two wire leads going to it. The fuse is silver in color and mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it. Leave plenty of wire to accommodate. There will be instructions included with your replacement kit. Ensure you follow the direction thoroughly and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging the old fuse and replacing it with the new one (been there). The fuse will eventually blow again. Follow the instructions provided and you can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop4.gif and they SHOULD have the part available. This is a known problem and a common fail item.
Posted on Dec 15, 2007
  • 3 Answers
SOURCE: Kenmore elite dishwasher
Thaqt was a great hint Thanks Ill use this web site again
Posted on Nov 22, 2008
codfish124
  • 36 Answers
SOURCE: Dishwashing detergent in rinse aid compartment
not good there is no way to drain it out. you might be able to take the door apart and take off the rinse aid reservoir and clean it out
Posted on Dec 20, 2008
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: Need the model number of the Kenmore Elite dishwasher 1378(2)
The model number will be something like 110.123456
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Feb 05, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Kenmore elite dishwasher wont work
Remove the console panel with T15. then remove the cover from the main control board. top right of center of the main control you will see a removable fuse, either a black disc with a black and a black/w white strip connected. remove one wire from the thermal fuse and check for continuity. if it is open replace it. if it is not open call for service.
Apr 30, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher elite door opens too fast, broken spring?
Could be that, the spring may have unhooked or it could be a defective damper connected to the door. Remove the side panels and check the operation of the door mechanism. (This will probably require the removal of the rear panel to gain access to the necessary fastners).
Jan 21, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a kenmore elite model 16582200 built in
Item #959376(fuse) will need to be replaced.
Unplug the dishwasher.
Remove the 6 screws holding the control panel on.
The fuse is on the top right side of the control panel. It has 2 wires going to it,usually black and white.
Remove the wires and check the fuse with a meter set for continuity. No continuity is a bad fuse.
If the fuse checks OK use the meter on the micro door switch found under the door latch.
Remove the wires to the switch,touch the meter leads to the 2 terminals and manually push the switch button in. If no reading on the meter the door switch is bad..
Jan 01, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
No power suddenly on the control panel... kenmore elite model 665-1374/665-1384 Worked one day and not the next. Breaker is on, no blockage at water line... connections all tight. It's only 14 months old!
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
Dec 30, 2009 | Kenmore Dishwashers
Control panel access
Open the door and remove the top screws connected to the console. Close the door and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Mar 06, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
48 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
