Question about Whirlpool Washing Machines
Whirlpool LA9100XTW0 stop agitating ... - Whirlpool Washing Machines
  • robert samples May 11, 2010
    try spin and let me know
Most likely the "agitator dogs" in the upper portion of the agitator. here is the kit you need to fix it:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2744&PPStack=1
it is a 5 minute job.
Posted on Aug 17, 2008
2 Suggested Answers
  • 20 Answers
SOURCE: directios for changing agitator dogs
take the cam out take the yellow bushing off, put new dogs in, put yellow bushing back on, put agitator back into washer, put cam back in with dogs inside it, facing down, put bolt back in and cap. new dogs usuaully come with instructions.
Posted on Feb 13, 2009
Whirlpool washer. the agitator just stopped in mid wash. there was heavy towels. . could the heavy towels have caused the agitator to stop.? does the agitator come off.?
the agitator cam be removed but that will not be the problem
if it has a belt drive , probably the belt broke or the agitator solenoid /engagement lever has broken
you will need the model and serial number when you call the technician for a proper diagnosis
May 14, 2017 | Whirlpool Washing Machines
Apart together whirlpool 3slsr6233mq0
have an electrician check the agitator module and the start capacitor as either results in your indications.
Aug 17, 2013 | Whirlpool Washing Machines
Whirlpool SM8280867 stopped agitating and makes noise.
you can find disassembly video on youtube,chances are you probably need a coupling,part no.285753a u can find exploded image/parts from sears .com
Mar 06, 2010 | Washing Machines
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
Whirlpool washer stoped after the agitate cycle
If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
May 19, 2009 | Whirlpool Washing Machines
MY WHIRLPOOL LAUNDRY MACHINE WILL NOT AGITATE
If it just fills and stops dead then its probably the door switch.If it fills and you hear the motor start and it makes a horrible noise then its probably the coupling between the motor and transmission. Theres also a slight chance its a stripped agitator spline
Apr 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Directios for changing agitator dogs
Feb 10, 2009 | Whirlpool Washing Machines
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washer won't cycle through...
The cycle timer may be defective and will need replaced. Hope this was helpful.
Oct 11, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal De
