Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
How do I defrost my samsung freezer without defrosting the fridge? Is there a way?
    President:
  • 1,430 Answers
A hair dryer or very carefully using a heat gun.
Posted on Sep 14, 2010
  • kentgehrke Jun 05, 2014
    It is self defrost there is no need to defrost it unless something is wrong with it . Why is it building up ice?
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
For Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
FRIG NOT COOLING - FREEZER IS FINE
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 27, 2011 | Samsung Refrigerators
Fridge defrosting
Sounds like the defrost is cycling on and off. The model number is incorrect and I will need a correct model number to help you better. Sea Breeze
Aug 25, 2009 | Samsung Refrigerators
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
SAMSUNG RS21DCNS
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
I have a samsung fridge freezer which is about 4 years old. The freezer is working fine but the fridge has gone off completely.
sounds like your evaporator fan ( in the freezer) has quir, or you have a defrosr issue, first, verify the fan is running in the freezer, if so you need to check the three defrost components. the defrost timer, the defrost heater, and the defrost thermostat,
Apr 02, 2008 | Refrigerators
Samsung RS2630AWW freezer works/fridge does not
Chances are the fuse in the evaporator section is bad and won't go into defrost automatically.  Samsung refrigerators are junk!  Good luck getting anyone to service this one.
Oct 17, 2007 | Samsung RS2630AWW Side by Side...
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
1,438 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
