Question about Sharp Zaurus ZR-5700
I installed replacement batteries with the polarity reversed. Since then unit does not display the Contact file, but all other functions (activities, data files, etc.) seem unimpaired. Any ideas? I really need the contacts, as I am lost without them. A check of the Memory file indicates a total of approximately 2500 entries in the three files.
  • Sharp Master
  • 12,061 Answers
Hi, well the reason this has happened is that these contacts are stored in battery backed up NVRAM, now this RAM is very sensitive to polarity reversal, and also due to the way it works, doesn't have polarity reversal protection, on that circuit. So when you reversed those batteries even though the reverse polarity protection saved the Unit as a whole, the NVRAM would have been destroyed or wiped at best. These is no real way of replacing this NVRAM, I guess you could send it back to the factory though and ask for a "Quote" with view to the repair.
Posted on Sep 15, 2010
Why my apc ups change its polarity after mains failuer
Probably because polarity at the plug is reversed, check for that.
There is a red LED at the back of the unit, if it is lit, polarity at the plug is reversed, you will have to correct this.
Apr 30, 2014 | APC Smart-UPS 1000VA UPS System
Installed battery reverse polarity.now installed correctly and no powerr
Follow the positive wire from the battery and it will lead you to the fuse box. Also watch for a in line fuse or fuseable link.
Mar 17, 2014 | 1999 Honda CBR 600 F(4)X
Polar a4 wrist watch
if you send us your display photo may can you help
you can countinue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 23, 2017 | Exercise & Fitness
Does the jl audio 250/1 have any internal fusing that would affect output . my buddy hooked up booster cables backwards and it did blow main fuse at battery but now lights are on and noboby is home.
I have seen circuit traces litterally burn up from reverse polarity. Also the capacitors on the 12 volt main line can smoke and causing the DC/DC circuit not to function. Traces can be repaired with the proper sized copper tape and capacitors are cheap. The only way to be sure is to open the unit up, look for strange liquids and evidence of burn or fire.
Feb 03, 2013 | Jl Audio 250/1 Car Audio Amplifier
Reversed polarity and now it keeps blowing fuses
For 25 cents, they could have installed a diode to prevent this problem, but now there isn't anything you can do, as the damage has been done by the reverse polarity.
Nov 10, 2009 | Cobra MR- F55 Base CB Radio
Only has a -1 on the display
Christoph, Likely you have the meter set to resistance (ohms) and thus, are getting the displayed reading you've described. Also, with the polarity reversed ( positive and negative + / - ) you'll get the negative number displayed in voltage settings.
First off, check to make sure that the battery inside the back of the test meter is new. If your meter has been around for some time, it is likely that the battery should be replaced. Typically it is either a AA or 9 volt battery in most testers.
Once you've replaced the battery, try testing the old battery with the meter set to DC-V and the probes (red & black) in the DC-V connections. Set the measurement scale to the lowest on the DC range and then with the red test lead on the battery's positive end and the black test lead on the battery's negative end, you should be able to get a voltage reading of the old battery.
Now you can check the resistance function (ohms) by setting the meter to the Ohms function at the lowest scale/setting and touch the two leads together. You should get a reading of 0.00 ohms resistance. You might have to zero the setting manually with either a small adjustment wheel on the face of the meter, or with a small set screw on the backside of the meter. (some models have this installed inside the battery compartment also)
Hopefully that's all the issue you've experienced and your meter is now working properly. I hope you find this Very Helpful and best regards!
Nov 02, 2009 | Actron CP7672 Digital Multitester
With all DC systems on no negative Ah readings
The shunt needs two (2) wires coming from it to your amp meter. If the meter reads backwards polarity, reverse the shunt leads.
May 28, 2009 | Xantrex Technology Xantrex LinkLITE...
I have a Honeywell T8131C programmable thermostat. Our power went out yesterday, and now the "Bat Lo" won't go away. We replaced the batteries, but the "Bat Lo" indicator stayed on...
I tried all the tricks mentioned previously to no avail.
These are the steps I performed to get it to work:
1. Remove batteries and make sure the battery contacts inside the unit are clean.
2. Disconnect all the wires from the back of the unit. Be careful not let any of the bare wire ends to come in contact with each other. Make sure you mark the wires or verify that the color code matches the markings on the rear cover:
W=White wire;
Y=Yellow wire;
G=Green wire;
R=Red wire (low voltage DC); and
C=Common (wire color varies)
3. Leave the unit disconnected with batteries removed for about an hour to make sure all the memory drains. I waited an hour, but it may not require that much time.
4. Install the batteries in the correct positions per the instructions. The unit should perform a power up display test, then the display will flash the time and temperature.
5. Set the clock and the display will stop flashing.
6. Slide the switch to cool and/or heat and program the desired weekday/weekend settings.
7. Slide the switch back to off once all weekday/weekend settings are made.
8. Reconnect the wires that were removed in step 2.
9. System should be operational at this time.
May 29, 2008 | Heating & Cooling
Meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
Apr 22, 2008 | Optics
Sharp Zaurus ZR-5700 Logo
127 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
