Question about Dishwashers
Kenmore Dishwasher Model 665.11643300 Cycle will not run. Normal Wash light blinking Cancel light will also blink (but can be cancelled by holding button down) I tried shutting down the power and resetting at the breaker. I tried other buttons like Air Dry, etc to see if there was some sort of sequence Note* last cycle ran was rinse cycle many months ago - house has been vacant and dishwasher has not been in use.
  • Dishwashers Master
  • 3,247 Answers
I will look a bit further in detail about your dishwasher problem. I am assuming you have checked the inlet water tap to the dishwasher is turned on.
Posted on Sep 14, 2010
  • Sam Sep 20, 2010
    Not sure what is the status with your dishwasher.
    I found the reset sequence for what might be your model of dishwasher.
    Press normal wash and heated dry one after the other about 5 times.All lights on panel will light.Wait until all lights go out and it resets itself.It will go into a mode on it's own.Then press cancel and set your options as you normally would and press start.
    If the button are not same then let me know as I may have the models mixed up.
  • Sam Sep 23, 2010
    looks like you have taken refund from fixya. It would have helped me if you had acknowledged the solution I had suggested to reset your dishwasher. Is that not what you were after?
Blinking cancel light, that won't cancel out, and won't allow other functions to be started.
While the door is closed, try pressing and holding the cancel button for about 10 seconds to see if it will clear.
Mar 31, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore dishwasher blinking E2F2
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Then you have to wait 2 minutes while your Kenmore dishwasher runs its diagnostic test.
Then press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop any lights from blinking.
Jan 29, 2015 | Kenmore Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Clean light blinks constantly
press heated dry
press normal wash
press heated dry again
press normal wash again..........
.....wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Feb 05, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
wait a few seconds
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
192 people viewed this question
Top Dishwashers Experts
