Question about GE Nautilus 24" Built-in Dishwasher
I have a G E Nautilus Power Scrub Dishwasher After our washer has gone through its' cycles water remains (about 2") in the bottom of the machine. What to do?
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
here2helpBSH
  • 27 Answers
SOURCE: Bsoch dishwasher runs long and displays 1 minute left on timer
sounds like a bad solder connection on the heater relay of your control unit. more than likely you will need a new control unit. part number 266746
Posted on Mar 19, 2009
MNTECH
  • 1543 Answers
SOURCE: My GE Nautilus dishwasher keeps PUMPING water "out" of the machine during the entire wash cycle. I have removed all covers in the bottom of the unit to see if anything is stock. Used vinegar and CLR
If this convert-able dishwasher is permanently installed, you will have to take off the lower access panel to get to the pump area. If it is still in a portable configuration, it may be easier to lay the dishwasher on it's back or side to do this. Now, examine the pump / motor assembly. There is not a separate water pump on this model. There is a diverter pump out solenoid which get's pulled down to direct the water out the drain hose for pump out, which is suppose to spring back out of the way to allow water to go up to the spray arms for washing. I suspect that the solenoid got to hot and the plunger will no longer slide in the solenoid. If this is the case, you can replace it with a WD21X802. If the arm and plunger move freely, check the spring, or for obstructions in the pump housing, or possibly the diverter arm in the pump housing has come loose from the shaft. The solenoid is the most likely.
Posted on Apr 30, 2009
SOURCE: Standing water in the bottom of the dishwasher
I had the same problem - a 10 minute fix. The issue tends to be that the trap gets clogged by debris (like broken glass etc.) and restricts the amount of water that can be evacuated by the tub.
1. Undo the trap cover (two hex headed screws)
2. Remove the trap cover
3. Remove the inner trap grate
4. BE CAREFUL NOW ! Gently remove debris - this can have broken glass in it !!! - You can use a wet vac if you have one. Ensure all debrs is removed and the trap is clear.
5. Clean trap cover and grate
6. Re-install cover and grate
7. Bingo !
Posted on May 10, 2009
SOURCE: Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Posted on Aug 05, 2009
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
Jun 03, 2017 | GE Nautilus 24" Built-in Dishwasher
I have a Bosch SHX46A05UC/33 5-cycle dishwasher whose labels on the cycle buttons have also worn away. While the Macmarkus post was helpful b/c I have some of the same buttons, can you tell me the labels...
Some SHX46A washers have 4 cycles and others have 5 cycles.
I'm fairly sure your model has the hidden buttons on the top of the door and you stated you have five-cycle buttons, in which case they will be as follows.
1. Top Rack only cycle or Sanitize
2. Power Scrub Plus
3. Regular Wash
4. Delicate Wash
5. Rinse and Hold.
These buttons are also used for cancelling a wash cycle. Hold down "Power Scrub Plus" and "Delicate" at the same time to cancel a cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration (from left to right) will be:
1. Power Scrub Plus
2. Regular Wash
3. Delicate Wash
4. Rinse and Hold.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Nov 21, 2010 | Bosch 24 in. SHX46A05UC Built-In...
Some water remain in bottom
In The Manual It States That There is supposed to be some to keep the seals Lubricated. It is normal
Sep 14, 2009 | GE Nautilus 24" Built-in Dishwasher
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
Water will not fully drain
put two dishwasher tabs in machine and run it as norm may be too much lime scale
Aug 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
2 year old GE Nautilus dishwasher
Check the pump, make sure it is working properly and pumping water out. If it is then check the drain hose and make sure it is not plugged.
Feb 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Stagnant water after running
first check all the screens in the tank and make sure their clear.there should be no water left in the tank.let me know.
Nov 11, 2007 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
