Question about Vtech EV2625 Cordless Phone
I have two ev2625 vtech phones and the 2626 base. Suddenly during a conversation the phone will drop the call (go dead). Batteries are a year old, but generally are well charged. The problem is inconsistant. This happened previously (that is why I replaced the batteries) previously. I recently unplugged the base from 110 power and removed both phones from their cradles. We haven't used the phones that much as of late, but so far they haven't dropped the calls. Has this been a reported issue and other that the mystery of electronics what might be the problem?
SOURCE: Not Registered
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Posted on Jun 01, 2007
SOURCE: Not Registered Problem
I had the same problem and I JUST fixed it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Posted on Apr 09, 2007
  • 298 Answers
SOURCE: vtech 5808
To far from base unit do you have
channel switch button if so try that
some phones only operate at short
distances its an inherent problem to
the phone I have a radio shack that
tries to cut out at about 25-30ft in
another room
Posted on Dec 01, 2007
SOURCE: Phones going dead
buy a new battery from ebay.
just type in the search box, 80-5808-00-00
(the battery number)
You should be able to get a replacement for around $6 incl shipping.
This worked for me anyway. (Same symptoms you described)
Posted on Jan 13, 2009
SOURCE: vtech 5808
I've been having problems with short battery life on my Vtech
5.8 Ghz model CS5121-2. Tried "zapping" the 3.3 volt batteries, which helps for a while.
Determined (via DMM) that the base unit battery charger reads
10.45 volts DC no load - while the remote charger reads 12.5 volts DC no load. Xfrmr output is supposed to be 7.5 volts according to info molded into the unit. Might be the problem!!!
Posted on Apr 12, 2010
How to listen to messages
The EV2625 isn't an answering machine. To listen to your messages, refer to the documentation for whatever answering machine or voicemail system you have on your phone line.
If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Feb 27, 2014 | Vtech EV2625 Cordless Phone
My vtech phone base keeps flashing line in use but there is no handset in use
See if you can open and check the line for conversation . or someone has a baby moniotr on the same frequency as your phone!
Sep 06, 2012 | Vtech 2-LINE 2.4GHz CORDLESS PHONE
How long do batteries last in a Three Handset VTECH 5.8 Digital Phone System?
batteries last up to 3 years and from e-bay are a fraction of that price
as for time in use should be at least 1 hour for a good battery
it is vital that after use you return the phone to the charge cradle
ensure that charger is operational
Apr 03, 2017 | Vtech Cars & Trucks
My phone keeps saying unable to connect
is your phone about a year old? It may be the battery. The vtech phones have weak batteries that clunk out after about a year and you'll get dropped calls, looking for base etc... The phone still appears to be working and the battery indicator tells you it's charged, but the battery is too weak to keep the wireless connection going.
Had the same problem and replaced the battery. budgetbatteries.com had the cheapest ones. But it's a knockoff, so I don't know how long it will last. So far it's been 3 months and the problems are gone. I would try that first and see how it goes. I paid about $15 including shipping. If you buy it from vtech it's at least double...
Sep 24, 2008 | Vtech i5871 Cordless Phone
Phone not connecting
I am having the same problem. Had it last year, too but bought new batteries for all the handsets and that fixed the problem. However, this year I can't find the batteries anywhere!
Jan 23, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech 5808
This model of phone have serious problem regarding the battery. This phone use a lot of juice out of the battery. I'm pretty sure that when your battery is foul charge it doesn't do it. So the problem is in the handset. When your battery starting to get to low you loose your connection. Why?...Because the detection to LOW_BATT in your handset is not calibrate adequately. So it thinks that the batt is weak, to weak to make a conversation.
The other problem could be that your handset doesn't really foul charge your battery. So when you are to far from the base or talking for to long . There's not enough power in the battery to raise the output signal level(db) to your base.
Nov 05, 2007 | Vtech i5808 Cordless Expansion Handset
Phones cant find base
I have two handsets, one of them recently starting dropping the connection to the base quite regularly [even if it was just inches away], and I ended-up in the same situation after unregistering the phone.
In my case, I was able to remove the battery from the phone [as you did] but also unplug the power on the base unit for several seconds. After restoring power to both, I was able to re-register the handset and it appears to be working more reliably now.
Jun 09, 2007 | Vtech i5871 Cordless Phone
Phones going dead
Jan 04, 2007 | Vtech IP5850 Cordless Phone
Vtech EV2625 Cordless Phone Logo
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
