Question about Canon imagePROGRAF iPF8000 Printer
Imageprograf ipf8000 printer says "execute print head cleaning, If this messsage is still displayed, replace Printheads l/r stop: stop printing and wont print test print, but in service mode it will and looks fine, how to fix anyone?
3 Suggested Answers
SOURCE: as to enter SERVICE MODE canon imagePROGRAF iPF700?thanks
Service Mode - With power off, hold paper feed (paper select) button and info button while powering on, release after initializing screen.
Posted on Jul 15, 2009
SOURCE: Mystery Print Problem with Canon iPF8000
If it's within 12 months of purchase, Canon will replace free, although you may have to hound them a bit. This problem has occured twice (2 new heads) on our IPF8100 each time about 9 months in.
Posted on Mar 11, 2010
I have replaced the print heads, and instead of printing red, which I made, it is printing black
DEAR FRIENDS; PLS DO THIS FIRST STEP FIRST
How to print nozzle check pattern iPF6100/iPF610/iPF710/iPF8000S/iPF9000S/iPF800/iPF9100
  1. Load unused paper.
  2. Press the Menu button to display MAIN MENU .
  3. Press or to select Test Print , and then press the button.
  4. Press or to select Nozzle Check , and then press the button.
  5. Press or to select Yes , and then press the OK button.The printer goes online and prints a test pattern.
Second later print out result pls compare you result print with my attachment picture.
replaced-print-heads-instead-printing-5j51azquscxy1hu2enwrxd50-4-1.jpg let say if anything color no same like example red = black,yellow = yellow black , cyan = dark or magenta = green.
this means got dirty on site purge unit and printhead unit. you need to call canon technician done services for you because i can't teach you how to clean the purge unit and print head unit scared you will spoil this both unit.
Hope can help you ,TQVM..
Apr 13, 2016 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Print head error
i have downGrade firmwares for IPF8100,IPF9100,IPF8000, IPF605,IPF700 UNLOCKS PRINT HEADS WHEN THE PLOTTER ASK YOU TO CHANGE THE HEADS. mail- a.louloudis1@gmail.com for questions and support
Jul 03, 2015 | Canon imagePROGRAF iPF8000 Printer
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
http://mail.davin.be:8888/CANON/BOOK%20IPF/IPF750/ipf750_755-sm.pdf
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Executive print head cleaning. if this message is still displayed, replace print head
executive printhead cleaning if this message is still displayed replace printhead
stop - stop printing
plz, I need solution, if u can help me
Aug 18, 2012 | Canon imagePROGRAF iPF9000 InkJet Printer
I have a Canon iPF8000 large format printer and a message comes up saying, "Clean Right P Head". I have cleaned the printhead as it states, but it keeps on showing on the printer screen. Because of this,...
Canon has bad heads for this LFP, it is not unusuall. Every model has this issue, canon even lower the price of head because of this.
When you replace the print head message disapears for some period of time.If Im not wrong I think that is P-01 or 03 print head involved.
Jun 15, 2010 | Canon imagePROGRAF iPF8000 Printer
Ipf 8000 error code 003800500-2f-2f
there is no enough ink in the head managment sensor.
Go to menu, test print, nozzle check, check the grids 12 pair of grids.
Check if there are any brocken grids.
After that you have to perform head cleaning B twice or more.
If the problem still remains then replace print head.
also perform firmware update to the latest version though the official canon site
Mar 31, 2010 | Canon imagePROGRAF iPF8000 Printer
Mar 09, 2010 | Canon imagePROGRAF iPF8000 Printer
IPF610 Canon "Print head needs cleaning"
I've had the same problem, and finally after hours of frustration, got Canon to provide a new PrintHead at no charge
Jun 02, 2009 | Canon imagePROGRAF iPF8000 Printer
No ink is getting to printhead in imagePROGRAF w7250
Your printheads are indeed clogged. (Note: all ij printers should be powered off when not in use! This retracts & seals your printheads.) Now, on to your problem. In your printer software, there should be a maintenance section. In there, you need to clean the printheads - this may have to be done *many* times - like 10-ish to clear (if still possible) clogged ink.
Hope this helps.
Cheers,
gurutim
Mar 19, 2009 | Canon imagePROGRAF W7250 InkJet Printer
Canon imagePROGRAF  iPF8000 Printer Logo
483 people viewed this question
old marine
old marine
