Question about Philips Magnavox 9P6034C 60" Rear Projection Television
The tv seems to be very dark when a low lit image of a movie or tv program comes on. We have the brightnes on at full level. What could the poblem be?
    Top Expert:
  • Philips Master
  • 14,553 Answers
The simple thing to check if the set has not been "serviced" for some years is dust.
With the back cover removed you will see three large black lens---they are the light source (red,green,blue) for your picture.
If the lens are dusty the picture will be darker and duller looking.
Clean with a lens cloth or a paper towel with glass clean sprayed on the towel.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 14, 2010
TV PICTURE IS TOO DARK
use the menu on the remote to ajust the picture depth & brightnes
Jan 14, 2013 | JVC 37" Lcd Tv - Widescreen [lt-37e488]
Philips 50PF9956 50" Black Levels
Did you try backing down the contrast?...about the only thing I can think of would be issues with the main board if its not an adjustment in the picture settings in menu
Nov 23, 2017 | Philips 50PF9956 50 in. HD-Ready Plasma...
Kdl46s4100 HORIZINTAL DARK LOW PART-VIDEO WITH DELAY IN THIS PORTION AND COLOR DIFERENT AND LOW BRIGHTNES BOARD TCON WAS REPLACED THE FAIL CONTINUE
LCD PANEL DEFECT CONTACT SONY CUSTOMER SUPPORT THESE MODELS SONY MADE RECENTLY HAVE EXTENDED WARRANTIES ON THE LCD PANELS BECAUSE OF HIGH FAILURE RATES THEY WILL MOST LIKELY FIX THE TV FOR YOU FOR NO REPAIR COST. CUSTOMER SUPPORT NUMBER 1(800)222-7669 GOOD LUCK
Dec 17, 2010 | Sony Televison & Video
Noticable flickering when viewing dark images.
Hello, I too experience this exact same problem. In my opinion, any television under 2 grand is probably going to have some slight imperfection as this; I have tried a few different ones myself. To some, it would appear to only be a minor annoyance, but to those who truly can distinguish a good quality picture between a bad one, or to those people, such as myself, who would find something like this to be unacceptable, this is a disheartening situation.
My friend, I have tried many different settings to see which ones might resolve this issue with the blacks in the picture, or at least reduce it to a barely noticeable level and I have found that when I select the CUSTOM picture mode, reduce the contrast to about 60, turn up the brightness to 62, turn OFF blur reduction,x/v/ color on, CATS on, MPEG NR ON, turn Dark level to LIGHT(this is important) add a little bit of extra color for ex. 52, and sharpness to 75, that this produces a pleasing to the eye performance when watching blu ray movies and dvd's. The flickering is reduced to almost nothing, and the picture quality actually appears sharper and more ethereal in certain ways.
The downside to this is that you are lacking some true depth in the picture's darks, but after your eyes adjust and you are watching a good quality movie, you will notice that there still sort of is enough darks there to compensate. Further fine tuning may produce even better results, jsut have to keep playing around with it. But I am now convinced after hearing somebody come forward with the same exact problem i'm having on the same tv, that it is not a defect but just an imperfection that you sometimes have to deal with when you don't spend like 5 grand on a tv. Good luck and happy viewing!
Jul 05, 2010 | Panasonic TCP42S2 42 in. TV
Centering problem
Sounds like it could be a "light tunnel" ~~ can you see a full but unevenly lit image in a dark room?
If so it should be. Made of polycarb mirrors and they fall to bits.
Mar 21, 2009 | LG 62SX4D 62" Television
Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Sep 17, 2008 | Samsung HL-R6168W 61" HDTV
Ultravision image dark
Good Day, tfarmer;
Since you have replaced the lamp, which is the normal cause for a dark picture. Have you checked your video settings?
The brightness level should be set at about 55 to 60%, the contrast should be set at about 90% and the video temp should be at normal or high.
If all these are set about this way, then I would think that the light engine might be going bad.
Good Luck, big IRISH.
Jul 29, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
LG 22lc2d bought at Best Buy
Try setting your black leverl to high in the Pictutre-Advanced menu.
Apr 19, 2008 | Televison & Video
Dark images too dark
Yes - go to mebu OPC off - and make sure active contrast is off in advanced settings
Feb 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Rca projection p46812bl not bright enough!
I would think that the black level and the contrast should be all the way up not down the black level is your brigthness . if lhese are all the way up you might try adjusting the screen controls inside the tv if you know how.
Oct 16, 2007 | RCA P46812BL 46" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
