Question about Nintendo DS Console
DS will not keep settings
You said to change the internal battery. Are you referring to the regular battery that runs the entire unit or a smaller battery located inside the unit.
    Problem Solver:
  • 9 Answers
The main battery is the only battery that keeps the DS memory there is no internal clock battery or anything so it will most likley be your main battery that is dead.
Quick point though, if this is the case your DS should not boot. if it does boot and the settings are lost then I would check the battery terminals to make sure they are connecting okay.
Other than this it could be an eprom on the main board at fault maybe.
Good luck
Posted on Jun 17, 2008
My ds lite won't turn on.
Regular tap water contains minerals that are left behind as the water dries out. So, even if you did get all the water out, the minerals can still cause damage. In addition, the DS has a 'soft power switch' and that means that as long as the battery is in the device (as it probably was when sprayed) there is electricity present that can destroy the unit while water is there. Most probably, the water already did some damage when the unit got wet and the minerals and/or previous damage may have finished the job later when the unit was turned on. Some water may have even been left in the system since it can hide in areas that the dry rice will not be able to "draw" out. The best way to dry out a device is quickly remove the battery, take the entire system apart and clean the individual components and run some distilled water over the components to remove the mineral content of tap water before it dries on the boards/contacts. The DS lite system is relatively inexpensive these days, I think your best solution might be buying a good used one off Ebay (units can be had for around $50 today). May want to take apart any cartridge you had in it the old one and check for water in there, just in case, before using it in the new(er) one, too. Sorry for the bad news.
Dec 04, 2013 | Nintendo DS Lite Pink Console
Tip
How to reset Nintendo DS Lite.
Remove the cover for the battery compartment. At the back of the DS Lite, the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not cause a reset in the unit.
Put the battery pack back. Just line it up in the compartment and push it back into place.
Replace the cover. Replace with the screw.
Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
on Feb 12, 2010 | Computers & Internet
How to reset your nintendo DS
Hi. Here's the procedure on how to reset the console. Take note that if you are going to do this procedure this will erase all of the data saved on the system and restore the unit to its original factory settings.
Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit, and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
  • 2 Take out the DS Lite's battery pack. There is a tab at the top of the battery pack. Insert your fingernail or the end of the screwdriver carefully into the edge of this tab and pop out the pack.
  • 3 Keep the battery pack out of the unit for at least 10 seconds. If you keep the battery pack out for too short of a time, it will not reset the unit.
  • 4 Put the battery pack back into the unit. Just line it up in the compartment and push it back into place.
  • 5 Replace the cover. Secure the cover back into place with the screw.
  • 6 Turn on the DS Lite. If the unit has properly reset, a screen will come up that reads "Before you begin, you must adjust system settings." You can now enter all-new settings and information on your DS Lite. If you do not get the system settings screen, you did not keep the battery pack out long enough. Repeat the steps and leave your battery pack out for a longer period of time.
  • Sep 12, 2010 | Nintendo DS Console
    I want ot sell ds i want to no how to wipe the whole thing
    Remove the cover for the battery compartment. The compartment is located on the back of the DS Lite unit and the cover has a small screw holding it in place. You will need a Phillips size 0 screwdriver to remove it.
    http://vodpod.com/watch/2607802-nintendo-ds-lite-reset
    Mar 16, 2010 | Nintendo DS Lite Console
    How do you restart nintendogs
    No No No! Bad Silver! Before You See The Nintendo Sign (It may be after) Press and Hold A +B + X + Y + L Trigger + R Trigger and that's all. Taking Apart Your DS gives you a 99% Chance of epic fail. -_-
    Feb 12, 2010 | Nintendo DS Lite
    Humminbird 343c will power down on its own
    Hi!
    If the unit shuts off on its own, firstly check your power supply. I keep seeing customers running their ssounders from a small, portable battery configuration that doesn't put out the correct voltage...mostly seen with AA size batteries being rated at 1.2 or 1.3 volts (8 batteries times 1.2 volts is only 9.6 volts).
    If the power supply is not the issue then I would say the internal power circuit is suspect...this can only be repaired by a competent repair person who knows how and what they are doing. If you open the unit up, you'll not only void the warranty, you run the risk of killing the entire unit from static shock.
    Best of luck in your repair!
    Mike
    Aug 24, 2009 | Humminbird 343c Fishfinder GPS Receiver
    Have ds time from military to regular
    you have to go to the main screen then at the bottom of the screen there will be a small DS click that and you will hit the menu
    Aug 06, 2009 | Nintendo DS Console
    When battery is changed date and image size need resetting
    Internal battery or capacitor may be bad and not holding charge to keep settings.
    Oct 20, 2008 | Fuji FinePix F700 Digital Camera
    Camera will not keep date settings
    I suggest u to contact the service people and they will change the internal battery to keep update with time and date. Every camera has internal small battery so has to change regularly
    Dec 18, 2007 | Fuji FinePix E550 Digital Camera
    you need to change theCMOS batter chip on the inside try www.cherryfusion.com or any company that fixes video game consoles
    Apr 12, 2007 | Nintendo DS Console
    Nintendo DS Console Logo
    54 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
