Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
I have the Bill Dance signature addition trolling motor not sure of the year and don't have a manual. Just bought the boat and the first 2 times out it worked fine. Then it just quit working. Is there an inline fuse on these? Or what other problem might I check?
5 Suggested Answers
  • 10865 Answers
SOURCE: Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Posted on Jan 18, 2009
wireguy212
  • 1627 Answers
SOURCE: I don't have any slow trolling speeds. Only fast
To hook up to 24 volts you need to join a positive cable from one battery to the source[motor or controller] and the the negative cable goes to the positive of the next of the next battery,then the negative [of battery #2] goes to ground,same for all 24 volt systems.If the slower speeds don't work then the rheostat in the accelerator handle could be at fault,but getting the 24 volts sorted out may fix everything.
Posted on Jul 22, 2010
SOURCE: motorguide t47 powerplus trolling motor
t 47 power plus motorguide prop wont turn but you can feel the power going to motor to try to turn it
Posted on Jan 01, 2011
SOURCE: Ihave a motorguide brute hyper 67 trolling motor
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
Posted on Oct 21, 2011
Battery dies after 3 hr fishing new battery
Hey Bill, What type (voltage/model/size..etc..) trolling motor do you have? How big is the boat/what type you are using it own? What speeds do you run it on? Please give me the info and reply to me.
Jun 02, 2017 | Boating
96 LUND TROLLING MOTOR PLUG WIRING 3 WIRES ON PLUG 2 WIRES ON TROLLING MOTOR CORRECT WAY TO HOOK UP
What is the voltage of the trolling motor (2 wire) (12V, 24V,36V?)you are trying to attach to the boat(3 wire). Please fill in more info and reply/repost to me. This is not a hard one!!
Thanks
May 26, 2017 | Boating
Wireless motor guide trolling motor. Do they make this brand without the annoying beeper that beeps every time the unit is given a new command.This is the only complaint I have and would love to purchase...
http://www.jonestrollingmotor.com/
These guys will help you - If they cannot.. you can't be helped..
but as far as catching bass.. I would really like to go fishing with you..I have sloughs that I will show you where I catch 7 pounders..or is that too small??
Jun 11, 2017 | Boating
Need Manual fo Sevylor 12V Trolling motor
The Sevylor electric motor does directly mount to any Sevylor and Intex boat with out the need for an additional mount.
Sep 29, 2011 | Sevylor SBM 12Volt Fishing Motor
Old outboard ground wire melting
1. Short in the trolling motor itself
2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!!
3. Bad/dirty/corroded battery connections
..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
Sep 11, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
We have boat that came with trolling motor, boat not used in 5 years what should we do to service the motor/minn kota 40at before we put in water we hooked to battery it spun and quit?? not sure what to...
My guess is the motor has leaked water into the lower motor assy (behind the prop). and needs to be cleaned up and the brushes replaced.
here's a schematic:
Edge 40
You can try this to check for water leakage:-
1) disconnect from power supply
2) remove the prop
3) you will see 2 bolt heads behind where the prop was. Remove ONLY ONE of them for now.
4) if you see the bolt (it's about 8" long) is covered in what looks to be blask, oily/watery or rusty condition then you know that you'll need to overhaul it.
5) if it IS the motor assy, remove the other bolt and disassemble everything noting their location.
6) I would recommend replacing the brushes Part# 188-052 and the seal kit 2883460.
Sep 23, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Apr 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Trolling motor will not spin with out being turned by hand.
Take the prop off and make sure the pin that goes through the shaft is in place. The prop could also not be sitting on the pin proper.
Nov 29, 2008 | Humminbird 575 Fishfinder
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
97 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
