Question about Dishwashers
Hi experts! The middle wash arm in the dishwasher (underneath the top tray) does not seem to be spinning resulting in dirty glassware etc. I have checked the arm for debris which is clear and clean. The only thing I can think off is there is not enough pressure being pushed through the pipe from the back of the machine. Unfortunately I do not know where to go from here? Please help! Thanks Paul
  • paulshepherd Sep 15, 2010
    Hi Macmarkus,
    Thank you for your reply. I don't think I can access the sump like the guy in the video. Mine does not seem that accessible? I have attached a photo below....ps I am in th UK!
    Hello, the model is: AEG Favorit 50870.
  • Dishwashers Master
  • 2,605 Answers
Welcome to FixYa,
Based on your description... I`d suspect a plugged or really dirty wash pump. It could ultimately be a worn out wash
impeller/chopper assembly, but I'd certainly try my suggestions before considering that.
The place to start for that is to pull the pump filter, spray arm and check for food deposit, broken glass, undissolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it, ( This will be applicable to most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air )
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
When you`re finished run it through a test cycle and see how it goes. You may even want to run it empty with just a bowl of "white vinegar" on the top rack for a dishwasher bath.
Let me know how you make out and what you find.
Regards
Macmarkus :)
Posted on Sep 14, 2010
  • Mark MacDonald
    Mark MacDonald Sep 15, 2010
    Hello again,
    Thank you for the reply. I must apologize, as I mistakenly assumed your dishwasher was of the type I provided the link for.
    Can you provide me with your particular make and model number and I can hopefully help you to that unit specifically.
    Regards,
    Macmarkus :)
There are no error codes showing, water is definately getting hot but dishes on bottom tray not cleaning, i have used few products specially designed to clean the dishwasher itself without any dishes in,...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. .
Jun 18, 2011 | Baumatic 23 in. BDW13 Built-in Dishwasher
The top shelf is not getting clean. There is food residue on the glassware that was not there at the start of the wash.
The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back
2. Close the door
3. Start any wash cycle
4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Regards,
BElectric.
Dec 14, 2010 | Frigidaire Professional Series 24 in....
Hi- my dishwasher is not cleaning properly. It seems to get enough heat, there is no noise, etc. About a week ago, it just stopped cleaning. It will go through an entire cycle and the cups are always...
Probably a blocked spray arm (part that spins around). Remove each of the spray arms and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Hope this helps
Jun 09, 2010 | Bosch SHU5315UC Dishwasher
Top Wash Arm not Spinning
water is not circlating, you need a circulation pump
Feb 24, 2010 | Bosch 24 in. SHV55M03GB Built-In...
Dishes in upper tray coming out not so clean!
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 09, 2009 | Kenmore 24 in. 16332 / 16334 / 16339...
Rotary jets not spinning
Hi there........Rotary jets not sinning can be caused by....(a) something impeding their rotation..dishwasher air freshner hanging in incorrect place...(b).incorrect position of upper tray resulting in large plates impeding spray arm rotation...(c).cuttlery basket incorrectly placed or loaded with cuttlery impeding spray arm...(d) wash pump blocked or damaged impeller resulting in insufficient pressure to spray arms...
regards Sir Galahad
Aug 12, 2009 | Dishwashers
Dishwasher not cleaning properly and everything tastes like soap
To start with reduce the amount of detergent you are using. 2 teaspoons of detergent is enough for any wash.
Probably blocked spray arms is the cause of the unit not cleaning properly. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results. The bottom spray arm is the easiest and just pulls out the other two in the middle and the top you have to unscrew like a childs lock on a tablet bottle. Push up from underneath and unscrew each arm.
Hope this helps.
Aug 12, 2009 | Miele 24 in. G638 Plus Free-standing...
GE Triton arms don't spin
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
How old is the machine?
Other wise you need hands on service! And a new machine will pay for itself in only a few years!
Bless You!
Sep 06, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Middle arm of dishwasher not spinning
I'm the one that reported the same problem in November as "Guest". I fixed mine finally. I removed the middle arm again and noticed that the holes that spray a jet ot water causing the arm to turn aren't the ones on top. On the bottom of the arm there's a small hole at each end. I looked and one of the holes had a small piece of crud in it. I had to use the tip of an ice pick to dislodge it back into the arm. I then ran water into the arm several times hoping to get the item completely removed. I never did see anything come out but I then ran water through the arm holding it so the water could run out one end. The piece didn't show up in the hole again so I tried washing it to the other end. It still didn't show up so I guess it must have washed out the first time. It's been 3 or 4 weeks now and the arm is still functioning perfectly. Hard to believe that one little piece of trash can cause so much irritation. Good luck on this being the problem for others.
Oct 28, 2007 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
Owen Barnes
