Question about Sony BRAVIA KLV-32U100M 32 in. LCD Television
I hv changed and replaced all three , the mother board, draffon board and power supply board in my KLV32U100m since it went off from the protection system. now the power gets on but no picture ( cannot see menu or any other system) but the back light is on
I just fixed mine. the picture would fade off but the power was still on. I replaced the A board (the one all the componets plug
into).It's been 3 months with no further problems.
Posted on Jun 24, 2011
    Scholar:
  • 120 Answers
I would check the ribbon cable that connects the LCD remove from connector and reconnect. The connector, ribbon cable or the points it connects to the LCD panel itself could be bad. The only way to really be sure is to install the LCD panel in a working TV and see if it works.
I have purchased TV's with cracked screens (that powered on) ebay fairly cheap for this purpose a couple time's and it has worked out well.
Posted on Sep 14, 2010
Can a microwave be repaired?
Yes it is repairable, but if you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. If light and turntable works than low voltage circuit (220V or 110V) works well. In this case the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or in the main board. If light and turntable does not work than fault could be in power supply elements like: power supply cord, transformer, power board, fuse (glass or ceramic, ussualy 8A, 10A or 12A) on power board.
Dado
Oct 24, 2015 | Kenmore Microwave Ovens
Whirlpool microwave keeps opening high voltage diode
If you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. According to your description, low voltage circuit (220V or 110V) works well (light, turntable...). Obviously the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or sometimes in interlock switch assembly or PC Board.
First, you must be sure which diode is blowed, reactifier or protect diode.
To check magnetron following this procedure:
Discconect the mains supply.
Check that the capacitor is discharged (by resistor 100 ohm / 10W or more).
Discconect the magnetron.
Measure the resistence between the disconnected terminals (should be app. 0.5 ohm).
Measure the resistance between the supply terminals (both) and earth. The resistance should be infinite.
Dado
Mar 12, 2015 | Whirlpool MT4155SPS
We have replaced the psu ,mainboard and t-con boards for the above model tv but it does not come on.Do you know how to remove any protection mode the tv might have? we have the remote for the tv. Than
How about the power supply board? Is it producing the correct voltages to operate the other boards? Is the voltage present on the end of the cables connecting the power supply to the other boards? Does the power relay click when the power on switch is pressed?
Dec 31, 2014 | Televison & Video
Rca D61W20 52 in power supply
If the deflection power board was changed with a known good one . then the HV splitter block would be suspect then followed by a bad CRT next. I would try removing one CRT drive board at a time by letting it hang free wires attached then trying to power up the set if it doesnt power up then try one of the other crt drive boards after reattaching the one you previously unhooked. If the set powers up if any certain CRT board is removed you will know the problem is that CRT. If it doesnt power up then its most likely the HV splitter. You can get replacement CRTs, boards and HV splitters that have warranties from www.tvrepairworld.com
Jan 22, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Powers up , has audio but no picture
Plasma sets have two separate power supplies; the main supply produces voltage for everything and may even produce a specific voltage for the high voltage required by the plasma display.
In your case, it is likely that the latter (HV) supply has failed.
This may be a separate board and if so, may be user replaceable since these are normally outsourced and just plugged into the set during assembly.
Removing the back of the housing, you are likely to see at least three boards. One of them (the main board) will have many components and most will be smaller in size. The main power supply will have much larger parts on it and the high voltage supply will likely be connected to it and have far fewer parts than the other boards.
It is possible but unlikely, that the main power supply is not providing voltage to the HV board for the display.
If replacement of the HV board doesn't restore the display, then it will be necessary to replace the main power supply too.
Aug 21, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Power comes on for two seconds then goes off. Trouble code is 21. Is this worth fixing?
The X-Ray Protect circuit monitors:
* Excessive High Voltage
* Excess CRT Beam Current
* Excess HV Circuit Current
The X-Ray line is normally High. If any of the monitored sources exceeds its' specific reference, the X-Ray line is pulled Low, shutting Off the TV. If X-Ray protect shuts the TV Off, pressing the Power button will turn the TV back On ( it will shut Off again if the problem still exist).
Possible Problems: Power Supply Fault, Sweep Circuit Problem, Doubler Board Fault or a leaking CRT. You may have bad capacitors in the power supply or the sweep power supply.
Check for CRT leaking, few drops of clear light oil. If this is leaking the fix is costly and not worth fixing.
Inspect for puffy capacitors on the power supply and sweep circuit boards, if you can solder replacing capacitors is cheap, middle pricing for replacing power supply or circuit boards.
Feb 28, 2011 | Mitsubishi Televison & Video
Hi sir iI have an copier ( aficio 650 ) with error code ( sc 401-2 ) I ried to change the transfer unite , mother board , and power supply . the same sc code is appear againe while coping . plz send me a...
Did you change the power pack?
Check the connectors and connection between transfer belt unit and high voltage board.
Also make sure the machine is clean (near HV board and transfer )
Feb 25, 2010 | Ricoh Office Equipment & Supplies
No video signal on computer start up?
if u have built in VGA take off the Rams wash them with some ethanol then dry them with a blow drier then put them back into place and if u dant have built in VGA wash it as well
Jun 22, 2009 | Computers & Internet
Dead mother board
The problem with power surges, or low power (brownouts) causing excessive current draw can cause multiple problems to motherboards. Even if you were to pinpoint and repair one problem that appeared to fix the fault, several other components on the board may have been weakened, and prone to fail.
If you are certain that the power supply is 100% ok, then replace the MB.
The best power protection is to use a UPS.
Jan 05, 2008 | Intel Motherboard
Sony BRAVIA KLV-32U100M 32 in. LCD Television Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
