Question about Acer TravelMate C110 Tablet PC
Power supply socket faulty
Put in the wrong adapter,something blew up in computer.
  • 111 Answers
Have it repaired or purchase a new one.
Posted on May 16, 2008
No power when plugged in? What did I do?
If you have a volt-ohm meter check that you have voltage at the plug to the computer. If no voltage, the power supply is bad or the socket does not have power (circuit breaker) change to a known working 120vac socket. Dobble check your laptop's power supply. If still bad, see if you can barrow one, or take laptop to repair shop and ask them to try their power supply. Then you will know to purchase a replacement.
Mar 31, 2015 | ASUS R1E-B1 Tablet PC
Why will a samsung galaxy 2 tablet not charge?
first go to a mobile shop ask hif it it is the problem of battry or some hardware problem inside the tab and also check the charger weather it works or not
Jul 24, 2014 | Samsung Galaxy Tab 2
Netbook turns off instantly when power cord plugged in - even when not plugged into power outlet!
Have you tried a different adaptor or power outlet other than that the dc jack on the notepad may need replaced
May 08, 2013 | Gigabyte Atom Series Netbook: Q2005 -...
Tablet has not been used for long time. It was given to me. Battery is empty for sure. When I connect PC to the power suppy it does not show any sign of life. No light - nothing. I tried the same without...
The power adapter may be faulty.
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.
Apr 28, 2011 | Compaq tc1100 Tablet PC
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2011 | Compaq tc4400 Tablet PC
My laptop will not charge. If I hold the connection at the computer, and jiggle the transformer portion of the charger cord, it will charge briefly, but not continously. I have unplugged and replugged the...
When you plug in the adapter and wriggle the power plug and the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. You can DIY but if not confident to tackle it yourself then, I suggest you get a quote for the repair first.
Nov 26, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
What do I need to use my Touchsmart tx2 in France. Do I need an adapter or transformer or both
You live in the US, right?
First check the voltage rating on your power supply / charger's primary voltage range. If it states around 110V only, then you need a transformer from 230V to 110V with an euopean plug. Make sure it's a real transformer (rather heavy, rated at ~100VA will be OK), and not a lightweight high-power adaptor, used for lamps, pressing irons, heaters and similar appliances.
If on your charger it states something like "90-240V", then it will cope with the standard european voltage of 230V, and the only thing you need is a travel adapter that will have an european plug on one side and an american socket on the other.
Oct 25, 2009 | HP TouchSmart tx2-1270us Tablet PC
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Acer TravelMate C110 Tablet PC Logo
83 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
