Question about Ariston Technologies AWD 121
Aritson Margherita 2000 AL108 D What do symbols mean on dial?
What do the symbols and dial settings mean on the electrolux diplomat lx
Symbols..Question mark means "Put a bag in me", checkered light means : "Change me, I'm dirty"....pre-lit power light means: "You have Powaaa" to the unit and the thermostat light means the motor is too hot if it comes on, (most likely from a hose clog) and needs to cool down before the motor will run again. The settings on the control valve basically have to do with the auto shutoff when the bag needs changed. The lower the valve is turned, the more full the bag will get until it shuts off. Hope that helps!
Apr 24, 2014 | Electrolux UltraLux 2000 Bagged Canister...
How to approximate a soak cycle?
no need just hit the pause or cancel button after 4 hours push the start and your good to go
Jan 18, 2014 | Ariston Technologies AL128D Margherita...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Margherita 2000
put belt on motor pulley. start belt onto large pulley. turn large pulley by hand so belt will slip on. does require some strength
Sep 07, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Ariston margherita 2000 advantage AWD10
Push the sun symbol button and set it on the time/or the function of the dryer. Thats it. I believe you were using the drying function without heating:)
Regards
Jan 24, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Ariston Technologies AWD 121 Logo
146 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
