Question about Olevia LT37HVS 37 in. LCD HDTV
Cant get an undistorted picture without ctopping
  • 4,889 Answers
What does the picture look like? Does it happen on all input sources(DVD, XBOX etc.,)?
Posted on Sep 15, 2010
How to get an undistorted picture without cropping. This is an Olevia, and it is not listed below.
I assume you have a wide screen tv? most TV show are broadcast in a square (4:3) format, on a wide screen television the screen is rectangular, so to fit the square picture on the rectangle screen you have to either crop the top and bottom, or stretch and distort the image. the only real solutions are either to watch everything in the 4:3 format (leaving the sides of your screen blank), or subscribe to HD which will broadcast most programs in a wide screen format with out distortion.
Sep 14, 2010 | Televison & Video
Hi, this is not really a problem. I have an Onkyo TX-SR604 receiver. I had polkaudio speakers RTi8 speakers that are no longer working properly. I am looking for recommendations for new speakers that can...
A receiver with the specs...
* "90 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven from 20 Hz to 20 kHz, with a maximum total harmonic distortion of 0.08%"
(*) The only acceptable statement of its power bandwidth in the manual.
... when fed an undistorted audio signal, used properly and not driven abto clipping is not particularly dangerous to any reputable speaker.
Driving any amplifier, even a modest one, into high distortion is more dangerous to any speaker than a high-powered amp pumping pure undistorted power.
Choose any speakers but low efficiency models if you want loud and clean sound.
Jun 10, 2010 | Onkyo TX-SR604 Receiver
Goodmans gtvl32w27hdf - screen is flickering and picture is darker than it should, but sound is fine. Have tried turning off and on. doesn't matter what channnel you're on and its the same for video so i...
It is most likely the screen backlight. LCD TVs have thin fluorescent lamps and a part called an inverter board which is a transformer similar to a light ballast.
Inverters are typically a $50-100 part and are trivial for any technician to replace. The backlight lamps themselves tend to go pinkish when near the end-of-life, and are a low-cost part, but it requires a lot of work to change the lamps.
IF the LCD display itself is good, then the screen image should remain perfect and undistorted...if the backlight fails altogether, you should be able to see the image by shining a bright flashlight directly on the screen (only as a test, not as a long term solution, obviously :) )
Oct 16, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Car makes funny niose when first accelerated
Could you give a little more info?
IE: Car make/model, age, diesel, petrol etc??
If the car is making strange noises whilst in 1st gearm then this could be a sign of wear on the gearbox.
I would suggest topping up your transmission fluid (either into the gear-box itself, or ctop up normal engine oil).
Oct 13, 2009 | 2004 Infiniti G35 Sport Coupe
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Won't stop scanning
L16 Disc coil needs adjustment, Audio is slightly off, and improper noise to DC squelch level detect used to stop scan on active channel. Set to an on freq signal like a NOAA weather channel, and useing a non-metallic tool, adjust to best sounding audio, probably less than a half turn either direction. An on freq signal moduated by 1000hertz, connect scope to speaker and adjust for highest undistorted recovered audio would be better if you could.
Dec 31, 2008 | Radio Communications
Page printing
If the dimensions of the picture your trying to print are not in a 2:3 ratio (same ratio as 4 x 6), it cannot fill the entire 4 x 6 area without distorting the image, i.e., you would have to "stretch" the dimension which has white margins right now to fill the paper. To print an undistorted borderless image, you will have to "crop" the picture so that the remaining dimensions are in a 2:3 ratio.
May 27, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Strange picture appears in CCD
I see this problem everyday : the CCD sensor is faulty ( see enclosed pic from a canon camera with similar specs ) this is why you can not capture normal undistorted images but have no problem with playback .Fortunately Casio will repair this free of charge so contact your agent.1057f04.jpg
Nov 14, 2007 | Casio QV-R41 Digital Camera
Olevia LT37HVS 37 in. LCD HDTV Logo
19 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
