Question about GE JBP24 QuickClean Electric Kitchen Range
My wife informs me that it takes twice as long to bake muffins in the over as it did before she started noticing this happening. She baked the muffins at 500 degrees the other day to get them done. what is the problem? I assume it is an element. Model JBP24G0K1AD
Krazytech
  • 725 Answers
SOURCE: GE modelJBP65G V2AD hitchen range
it sounds like your TO8 CONTROL it is you oven controls and clock. let me know if you want to replace it ..
Posted on Aug 25, 2007
jsrock516
  • 5911 Answers
SOURCE: baking element not working
If you have already replaced the bake element (which would have been MY first logical choice) and it still does not work, the problem is more likely with the Electronic Clock Control. The control has two separate circuits that will select and turn on either the bake of the broil elements. It is usually a defective relay that causes the particular mode of choice to stop working. The part number for the ECC is 1166040 and costs about $128. It's not a cheap fix, but it would cost you much more if you had a service man fix it for you. Unless...of course, you still have a warranty. Most manufacturers cover all parts from defects for the 1st year. Some parts are covered longer than the initial warranty, however. It may be worth you while to double check your purchase date and appliance paperwork. This repair is not difficult and can be accomplished by the average do-it-yourselfer. If you decide you want to repair the appliance on your own, let me know and I can give you step-by-step instructions on how to do it.
PS Double check the wiring from the ECC to the bake element as well. You could have a broken wire causing the same symptoms too. Also, don't be alarmed by the failure of the ECC. Although they are generally reliable for quite a number of years, they have been known to fail during electrical storms and/or power surges. Something else you may consider: check your home owner's insurance policy to see if it covers the loss of appliances in the event of such incidents. I hope you find this information helpful.
Posted on Jan 24, 2008
MNTECH
  • 1543 Answers
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
MNTECH
  • 1543 Answers
SOURCE: Re: GE Electric Range JBP67BD1WH Baking Element Problem
Before you replace the range, I'd try replacing the oven temp sensor (part number WB21T10007 ) which is rather inexpensive. If I were able to get my hands on your range I'd first test to see if the control is sending 240 volts to the bake element. We know there is 240 to the range because the burners and broiler work, but is the control sending the full 240 to the bake element ? The only way for you to know this is to use a meter and test the voltage across the terminals of the bake element when in bake. Of course you should also test the bake element with power off and at least one terminal disconnected to see if you have about 20 ohms resistance across the terminals and no resistance from a terminal to the frame of the range. If not, you may need a new bake element (part number
WB44T10010 )
Let me know if I can be of further assistance. Thanks for using fixya.
If this helps, a fixya rating would be appreciated. Thanks.
Posted on Nov 08, 2008
Maytag317
  • 1136 Answers
SOURCE: No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
Posted on May 31, 2009
I froze my box of blueberry muffin mix by mistake will it be ok to bake?
1 sure fire way to find out, give it a go if it works fine post on here as a tip.
Mar 26, 2015 | Betty Crocker Blueberry Muffin Mix Case of...
While baking muffins, taking the 2nd batch out of the oven I noticed a smell like an electrical burning smell. Just then the oven started beeping and flashing a F08 and F07 code. I tried to turn the oven...
Looks like you have a runaway temperature problem.
I will guess that the oven is electric and the top burners are gas, as it is with most dual fuels.
Like like an oven sensor or board problem. The quickest way to find out what the error codes mean is to Google it. Then re-post your question for a more specific answer.
The error codes should also be in your customer user manual.
Oct 20, 2013 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Have a Panasonic Bread Bakery SD-YD205, the book does not have anything about removing the beater blade before the baking process starts. Can it be done without interfearing with the baking process? Thank...
I have a bit of experience with this one.My wife says she never removes the blades before baking .When your machine punches down your dough for the last time before it bakes...and if u can catch it in time u can remove them,but its not necessary.
Dec 16, 2010 | Vacuums
Our range suddenly takes a lond time to come up
thermostat or board...would need the model#
When you have determined your part you need check out www.appliancepartssolutions.com
cheep parts!
good luck
Jan 19, 2010 | Kitchen Ranges
Summit electric range overcooks bottom of baked goods
have it calibrated or get oven thermometer and figure differential yourself, say it runs 30 degrees hot etc
Aug 23, 2009 | Summit Appliances Division Professional...
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
Won't heat up
You have two ignitors one for bake and one for broil your bake is not working
Nov 09, 2008 | Maytag CWG3100A Gas Single Oven
GE JBP24 QuickClean Electric Kitchen Range Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
