Front loader GE model wsxh208a1ww. During spin it stops working and a loud buzzing sound comes from the door lock area. The water does not drain, have taken off the lower front panel and checked for obstructions, now what? Is the pump bad??
natengel
  • 19 Answers
SOURCE: ge front load washer won't spin
replace the drain pump.and 2 remove the control panel u need 2 remove the 3 screws from top cover from the back
Posted on Nov 01, 2007
Coldcut
  • 1554 Answers
SOURCE: Frigidaire FWTr445rfs1 front loader - door closed but buzzes during washing
by the way it too fixya over 14 hrs to relay that message
Posted on Apr 16, 2008
SOURCE: GE WBVH6240
All,
There are three screws under the plate beneath the door. Remove these three screws and remove panel. Immediately you will see a removeable plug about 2 1/2" in diameter made of white plastic. This is where your problem lies (or at least one of them). CAUTION - before you remove this plug, put a bucket under it because water will come out. After you unscrew the plug completely, pull it out toward you. You will no doubt find many items that washed out of your cloths. I found legos and coins tangles up with strigs and lint. The entire area was completely plugged. The coins were probably the source af the stains we had on our cloths as they were all black from the water and soap.
The pump on mine burned out and I am trying to replace it. Then I will sell this junker.
I hope this helps some of you. Please advise.
Posted on Aug 11, 2008
tomsat69
  • 219 Answers
SOURCE: Loud noise coming from bottom of washer during spin cycle
If it is a ge kenmore it sounds like your tub bearing is dry and needs to be replaced.The reason i say ge kenmore is because they fall under differant companys depending on witch year you bought it
Posted on May 07, 2009
  • 234 Answers
SOURCE: During the spin cycle the machine made a loud thud
It is doutful the basket or drum has warped. With such a loud thud and still doing it when you use the machine, it appears one of the balance springs or its mounting has broken loose. This will require opening the shell of the machine. Some models have a 3 point suspension, others have a 4 point suspension. This broken suspension point will account for the fact that you can spin the drum feely by hand yet it goes crazy when spinning with a load.
Because it is a front load unit, you must be careful or have a certain level of knowledge to open the unit and reclose it with the drum, seal, and facing all lining-up and not binding. As always, unplug the unit before taking it apart. Good Luck. Macgivor
Posted on Sep 20, 2009
GE front loader spins slow
need the Model number to help you find the white tag and add the model number it inside the front door frame
Feb 03, 2018 | GE Washing Machines
I have a Hotpoint Aqualtis wash/dryer which stopped working with a 'F12' fault. Now when I turn the socket on I get an immediate really loud whir/buzz.
possibly the main drive belt has either snapped or jumped off the pulley and this allows you to turn easily by hand the whir/buzz sounds like system in coming into play but with no belt to drive nothing more happens, the front lower portion of the machine could be the water pump working overtime unable to drain ???
May 09, 2016 | Hotpoint Washing Machines
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
My GE spacemaker top loader will not drain, makes buzzing noise
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
Washer starts/ stops
recycle power. if problem persists, timer problem
Mar 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
May 07, 2009 | Whirlpool Inglis IP4400 Washer
LOCK AND LOAD ISSUE
can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Jun 28, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
