Question about Vizio VX32LHDTV10A 32 in. LCD HDTV
Vizio 32" is about 3 year old and turns white when turned on and stay white. Can get some audio from selected channels but not all of them. Whats wrong? I will unplug to re set aqnd see what happens.
  • Vizio Master
  • 8,457 Answers
Reset by unpluging,will not solved this problems.The tv Tuner board is dead,that the board where the incomming broscasting signal cable plug into it.The Tuner board,have a IC call a Mosfet is dead,not distributing voltage to the main CPU anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Sep 14, 2010
Vizio Model SV320SVT powers on, after Vizio splash screen it goes blank. Power stays on, but no backlight on screen.
Yes its very repairable as long as the logo stays white you can assume the main boards good. I would recomend contacting the people at www.tvrepairworld.com by hitting the contact us button from their website. They will be able to assist you in finding out whats happening with the set for free. They have most parts available as well.
Aug 07, 2012 | Vizio SV320XVT 32 in. TV
Is my tv repairable at a reasonable rate if the screen turn all white all of the sudden? It won't change channels or turn off, we have to unplug it to turn it off
repairs can easily cost more than a new set and this particular brand seems to have its share of issues i would recommend a different brand like toshiba,lg,samsung those are a couple of the budget tvs that will last the years a set should i personally use toshiba they have good deals and the quality is awesome and has features not available in other tvs 2 times the price like the ability to audio in hdmi then out with red and white to your theater system most tvs are not able to transfer that signal within the tv and leave the audio out on the tv mostly useless ya get me ? shop around and take the knowledge of what your tv lacked and find the perfect replacement to suit your needs i hope this helps you in some way as your not alone in having an issue with your vizio good luck and happy new years
Jan 12, 2011 | Vizio L32 32 in. LCD HDTV
I have cable hooked up to my tv. Now I am trying to add dvd player, but nothing is showing up like I have it connected.
If you look at the rear panel, you will see the sticker showing AV1 and AV2 for the composite Video and Audio in.
Use AV1 inputs, just match the colors of the RCA JACKS at both ends of the cables, Yellow is for Video, Red is for Right channel audio, White is for Left channel audio. Just match the color. The using the remote to select AV1 then you can watch DVD. I have same model.
User manual: http://www.vizio.com/l32hdtv10a.html#support
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 15, 2010 | Vizio L32 32 in. LCD HDTV
When I turn my 32" one year old Vizio on either by the remote or by the side of the TV, it turns on and off about 15x before showing any picture and staying on.
U know how to solders?Power supply board have problems with dead capacitors,like bulge up or pop open .Replaced these capacitors well solved the power problems.Or u can buy reburbish power suppply board for the replacement at Shopjimmy.com,Ebay.com.
Feb 21, 2010 | Vizio VP322 32 in. Plasma TV
32" YEAR OLD HDTV WILL NOT TURN ON!
Ur signal turner board is dead,must change.
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
32 inch vizio will not turn back on, just stays orange in front
Try unplugging the tv and holding down the power button for 30 seconds than pluuging it back in and if it does not come back on the tv will need a repair to the power supply, just call tech support and make sure to have the serial number and the reciet handy so they can get you registered on the support system. Hopefully your tv is still under the one year mark than the repair will be free if not it can get expensive fast. Me personnaly have worked for vizio for about a year now and honestly this is a very common problem with theses tv's.
Mar 26, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 32 inch flat screen
have you find out anything about it ?
Jun 04, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VX32LHDTV10A 32 in. LCD HDTV Logo
124 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
